Window motor replacement
Old Jun 23, 2024 | 12:11 PM
bobfl's Avatar
bobfl
1999 Expedition XLT 4x4 5.4L
Drivers side window is up and does not function. When pushing the window button I hear the relay clicking.
There was none of the typical grinding noises when the regulator goes bad. I assume that it is the motor only. All the other windows work.
I understand it is possible to change the motor without removing the regulator. I know I will need to tape the window up. It seems that I saw something
about the regulator spring releasing when the motor is removed. Is the correct? If so how do I avoid that happening? I have replaced regulator/motors on
too many occasions on other vehicles, one being a 1999 Crown Victoria.
Any thoughts or suggestions will be appreciated.
Thanks in advance
Bob
Old Jul 1, 2024 | 09:17 AM
bobfl's Avatar
bobfl
FYI
After more investigation the motor can be removed without removing the regulator. See youtube video link below, about 6:45 minutes in. I removed my motor and started to test and clean it. After 25 years it still worked, but a bit slow, contact cleaner to the rescue. Put it back together all all works as it should.
If it decides to quit working I will replace the motor. I’ll post back if a new motor is needed in the future.
The nice thing about the regulator in my expedition there are no cables, it is all bars and rivets. So less to break.
bronco6767
Apr 15, 2016 10:20 PM
Dsl Lover
Jan 19, 2010 09:55 AM
Boz86
Nov 26, 2008 05:48 AM
cstrack
1997 - 2003 F150
35
Jun 26, 2008 04:18 PM
pherve
Jun 7, 2007 04:21 PM
