Class E all terrain
Old Jun 20, 2024 | 08:26 PM
Harveyearlolstad's Avatar
Harveyearlolstad
Class E all terrain
Hi all, 97 f350 cclb, I noticed my truck has class E rated tired. What is a tow capacity for these tires I'm looking to tow a camping trailer with a dry weight of 6500 lbs?
Old Jun 20, 2024 | 08:48 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Look at the manufactures website. But since you did not specify what tire or rim, never forget the rim they are on, we will not be able to give you the proper scientific response.
I am sure being a 97 F350 that your tires are way over rated for the vehicle they are attached to.
You will be fine.
Old Jun 20, 2024 | 08:53 PM
Harveyearlolstad
They are the stock steel polished Alcoa rims. The class E indicates 1520lb rated each individual tire load which I assume is linked to the vehicle weight and not necessarily the tongue weight? Sounds right?
Old Jun 20, 2024 | 08:56 PM
Harveyearlolstad
They are bfgoodrich all terrain lt285/75r16 126/123r
Old Jun 20, 2024 | 10:39 PM
Veteran: Navy
Check your numbers. Your thought on E rating is not correct. See the graph for load index.
Also those are Aluminum Rims. You have the incorrect nuts on those rims. You need the flat washer type lug nuts for aluminum rims. You need to check for damage.
Old Jun 20, 2024 | 10:41 PM
Harveyearlolstad
Oh, thanks I will have to get the correct lug nuts, thanks. They came with the truck and wheels. Thanks again.
Old Jun 22, 2024 | 06:44 AM
Desert Don's Avatar
Desert Don
Know before you buy. Since your truck is a ‘97 you may have lug centric wheels rather than hub centric.
https://www.discounttire.com/learn/h...vs-lug-centric
theboom
Jan 13, 2023 06:01 PM
smokersteve
Sep 2, 2012 10:44 AM
Jarniscipus
Feb 20, 2011 01:01 AM
Douglas DC-9
Apr 11, 2007 01:07 PM
aquaholic
All Things Towing
22
Mar 21, 2007 05:29 PM
