What is this?
Old Jun 20, 2024 | 12:31 PM
78Custom302's Avatar
78Custom302
What is this?
I am trying to repair the wiring after a fire. What is this circled in red? It seems to be a cluster of wired that go into this connector that dead ends....
Old Jun 21, 2024 | 06:44 AM
FuzzFace2's Avatar
FuzzFace2
It looks tobe on the wrong side to be a jumper for the NSS if you have a manual transmission and would think it would be inside the cab?
Over on that side I would think if you had factory AC it would got to the HVAC say the fan?
I cant remember now on my 81 but the factory AC was a add on harness to the main harness and think there was a jumper if it did not have AC.
With out the jumper the blower fan would not work. Mine was inside the cab but yours?
Dave ----
Old Jun 21, 2024 | 09:53 AM
78F150_Ken's Avatar
78F150_Ken
I'm thinking neutral safety switch for a 78 and newer model. My 77 was in the cab, but 78 in the engine bay right behind the carb when connected. Go to the trans and trace it up. My best guess is that it is either not connected or missing.
My 78 once drove through my garage wall...previous owner hotwired the NSS. I was tweaking the engine and instrument cluster, reached in to start it and it took off.
Both of my trucks are automatic trans.
Old Jun 21, 2024 | 12:05 PM
FuzzFace2's Avatar
FuzzFace2
Being there are no other wires going to the transmission and no open plug in that plug and the jumper i am guessing manual transmission?
Dave -----
Old Jun 21, 2024 | 02:25 PM
78Custom302
How do I replicate the wiring? Right where it joins the harness, it's all welded together into a giant mess. I don't think I'll be able to trace the wires.
78Custom302
It is manual trans.
Old Jun 21, 2024 | 02:26 PM
78Custom302
So ignore it?
Old Jun 21, 2024 | 06:18 PM
1TonBasecamp's Avatar
1TonBasecamp
Originally Posted by 78Custom302
So ignore it?
Not if you want your engine to start with the key.
The two red wires with blue traces, with the jumper on the other side of the connector, are from the ignition switch to the “S” post on the starter relay/solenoid.
What year is your truck? Sounds like a 78 or 79, so I’ll go with that for now. Or perhaps they changed in late 77, but you will definitely need to deal with many of those wires. looks like they would’ve normally been run over more to the driver side after exiting the firewall.
Funny, but your firewall looks to be an older truck. Maybe it’s just the fact that there’s no factory AC.
some of those other wires look to be important as well. Re w/green for the coil perhaps, along with the coolant temp, and oil pressure wires, maybe.
More pictures might be good, or describe the colors of the wires to us
Old Jun 21, 2024 | 06:20 PM
FuzzFace2's Avatar
FuzzFace2
Well there is that jumper you have to put back in place.
I would try my best to pull the wires apart so I could see where they go.
From the looks you only need to worry about the 2 wires with the jumper as the others do not look to be going to anything in the plug.
Unless that jumper has 3 wires going to it?
As bad as the wires are burned up you will have to pull them apart for tracing.
Dave ----
Old Jun 22, 2024 | 05:39 AM
78F150_Ken's Avatar
78F150_Ken
Dude, I'd consider a total rewire. Not cheap, not hard but I'd also be worried about gremlins. I also had my harness fried but from the instrument cluster to the starter solenoid. American Autowire harness did me right and allowed me to remove several extra relays I'd added on. Again, not cheap but not hard to install.
Sure, you can fix that, wire by wire though. Id get the laminated wiring diagram from classic car wiring.
Old Jun 22, 2024 | 04:36 PM
FuzzFace2's Avatar
FuzzFace2
No one said it would be easy but you can see what strains go with a wire.
Use a knife to cut the melted cover but leave the strains till you get back to good wire.
Once back to good wire and you have a bunch of different color wire on hand cut 1 wire at a time, soider and heat srink it in place.
Do 1 wire at a time till all are replaced. For melted plugs do you really need them?
If so my NAPA has different number of wire pig tail plugs and use them in place.
Dave ----
Old Jun 23, 2024 | 06:53 AM
mburger385's Avatar
mburger385
I have a ‘78 250 with that exact jumper. I had traced it once but now forgot where it went because I was looking for something else.
I’ll trace it this AM and post back.
Old Jun 23, 2024 | 01:36 PM
mburger385's Avatar
mburger385
My truck was a manual 4 speed converted to a C6.
On my truck, the red/blue goes from the ignition module then passes through the NSS then on to the starter solenoid.
Old Jun 23, 2024 | 02:10 PM
1TonBasecamp
I believe a separate wire goes from the ignition switch to the ignition module. Same color, from the same position on the ignition switch, but separated from the starter relay wire.
The wire we can see in the pictures comes straight from the ignition switch, to that connector, through the jumper and back out the other one and onto the starter relay.
With an automatic transmission, the neutral safety switch is connected there with it’s four wires. Including two of the red with blue for the start function, and two with a black with red (I believe) for the backup lamps.
The jumper is used on manual transmissions, and the neutral safety switch is used on automatics.
Old Jun 24, 2024 | 03:53 PM
78Custom302
Sweet! Thanks!
