4x4 parts
Old Jun 19, 2024 | 05:32 AM
ready4excursions's Avatar
ready4excursions
5th Gear
4x4 parts
Long time lurker. Thanks everyone for the great posts.
I'm converting my 7.3 diesel from 2wd to 4wd with locking front hubs (no electronics). I know it would be easier to just find a 4wd version but my 7.3 is mint and only has 108k miles. I found a donor excursion for parts sale (engine blew) that is 4wd and I can pull the parts I need. The owner is asking for a list of parts so he can give me a price. Please let me know if I'm missing anything.
Parts:
-Front axle
-Front suspension (leaf and brackets)
-Front driveshaft
-Rear driveshaft
-Transfer case
Old Jun 19, 2024 | 05:39 AM
charlie g's Avatar
charlie g
FTE Community Team
your going to need everything from the flex plate back, trans,transfer case, cross member, linkage and wiring for electric shifting if it has it , both drive shafts ,both rears, front steering , it's a way bigger job then you may think and by big i mean very big
Old Jun 19, 2024 | 07:42 AM
WE3ZS's Avatar
WE3ZS
Is the donor EX also a 7.3? The 4R100 trans has different internal parts between the 5.4, 6.8 and 7.3 as the torque increases with each engine. You can’t just slap a transfer case on the end of the RWD trans, the main shaft needs to be swapped to the longer 4x4 version and that requires disassembly of the trans, much easier to swap transmissions.
Old Jun 19, 2024 | 07:43 AM
John in OkieLand's Avatar
John in OkieLand
probably easier to just buy his truck as is, and take it home,
and pull what you need, as you need it
Old Jun 19, 2024 | 09:34 AM
Antonm23's Avatar
Antonm23
If you’re going through all the effort, why use stock Excursion parts?
Excursions came with a solid Dana 50 front axle, whereas the superduty trucks of the same time came with Dana 60s.
And since you’re swapping a 2wd, why go with front leaf springs? Plenty of information out there on putting the 05+ coil spring front suspension on an Ex.
Lasty, since you need a transfer case anyway, why buy an electronic shift NP273 out of an Ex , when you can get a manual shift NP 271 out of a superduty and not have all the headaches associated with the electronic shift?
I’d be down for the struggle of converting a truck from 2wd to 4wd, but I don’t see the point of using an Ex front axle, front suspension or transfer case in doing it.
Old Jun 19, 2024 | 03:57 PM
rsqfxr's Avatar
rsqfxr
Parts:
-Front axle
-Front driveshaft
-Rear driveshaft
-Transfer case
My buddy did his 7.3 truck, donor was a v10, it went pretty smooth and not as bad as people say, i wonder does the excursion have the knock out in the floor for the manual shifter, you will also need the tail section and shaft from the donor trans and possibly a manual transfer case
Old Jun 19, 2024 | 04:21 PM
Antonm23's Avatar
Antonm23
Yes, the Excursion has the knockout in the floor for a manual transfer case shifter (well, at least my 2005 did, pretty sure they never changed the excursions' sheet metal through the short 6 model year run). But if you want to use it, you have to lose the rear seat heat ducts.
CarlosGato
Jun 21, 2023 11:33 PM
Honda Monster 222
1983 - 2012 Ranger & B-Series
Dec 2, 2013 08:00 PM
zukinut
Feb 19, 2012 05:28 PM
51chris
Oct 14, 2011 12:32 AM
