change 2001 2wd ford ranger to a 4wd
That would be a huge undertaking and not at all cost effective. It would be much easier if you had a donor truck that was the same year and model as yours to make sure that you got all of the needed parts but it still would be a huge undertaking. I agree with g k50, just go out and find yourself a 4x4.
Welcome to the forum!
Why do you need a 4x4? You might at least take a minute to consider leaving it a 2wd. I pretty much had the opposite conversation with my dad 12 years ago when buying my 2wd ranger. He was strongly suggesting I get a 4x4 and my position was a 2wd was less expensive. Truthfully a 2wd will also get better fuel mileage and there are quite a few less parts to break so it's been very dependable for me and I'm still happy with the decision I made. We do have snowy winters here in Michigan but keeping weight in the back along with a shovel I've never gotten stuck to the point I couldn't get myself out. If you really need a 4x4 then seriously consider having another conversation with your dad about trading the truck in for one that already has 4wd. Like mentioned above there are a significant amount of parts that will need to be swapped (i.e. transfer case, drive axles, entire front end, dash buttons and wiring). It just isn't worth all the trouble to modify a truck you have no attachment to.
on
Aside from the obvious issue of parts availability, there is also a hugely significant safety risk with making this kind of conversion.
You, clearly, don't know what you're getting yourself into. If anything goes wrong with that conversion down the road, it could potentially kill you.
Besides, it's not a good idea to become too dependent on the 4WD. I've known a few very skilled drivers who could drive circles around 4WD vehicles with their 2WD rigs. I would suggest sticking with the 2WD until you become a more experienced driver, then move up to the 4WD. Maybe get a second truck later on down the road and keep both trucks...
There's probably a reason why your dad wouldn't buy you that 4x4...
Here's a guy who did it: 2wd to 4wd - The Ranger Station Forums
But keep in mind that his truck is an Edge model. On Rangers, the 4wd models all have torsion bar front suspension. Most of the 2wds have coil springs. The only 2wd models that have the torsion bar front suspension are the Edge models. So, this guy who did the conversion was already well ahead because his truck already had the same front suspension as a 4wd.
momutt
20
12-19-2015 01:41 PM
kay
1983 - 2012 Ranger & B-Series
09-29-2001 11:12 AM
