LED Lights
Old Jun 17, 2024 | 02:24 PM
Green72F250's Avatar
Green72F250
LED Lights
I have a 1972 F250 and am "trying" to go to all LED lights. I have replaced all the bulbs except the following: brake indicator light 1445 bulb, cigar lighter 1445 bulb, heater control bulb 1895?, and engine compartment lamp 631. All are single contact base lamps. I have been looking at Amazon, and e-bay, and have found some prospects for the 1445 and 1895 LED replacements. My questions are 1). Has anyone found a particular source or brand that they really liked that fit properly in these lamp sockets. 2). Is it necessary to replace these if you have LED turn signal and 4 way flashers installed in your truck. 3). What's the issue with polarity, as I see some LED flashers have connectors for changing the polarity on your truck. Thanks for any help!
Old Jun 17, 2024 | 05:22 PM
RTT's Avatar
RTT
Will you kindly list what you replaced all the other bulbs/lamps with . Did you need a voltage or amp converter for the L.E.D.S.'s
Bulbs are technically lamps
Old Jun 18, 2024 | 12:46 AM
Green72F250
I got some of the LED's from this guy on e-bay, and some from the local parts store. If I had to do it all over again, I would just buy the set from him.
F100fasteners | eBay Stores
I bought the flashers from him, and the cargo lamp, dome lamp, and license plate lamps from him. (all LED). Don't know about needing a voltage or amp converter, still trying to figure this all out. This is the kit for the 1970-72 Ford trucks.
Old Jun 18, 2024 | 11:59 PM
Green72F250
Does anyone know how the polarity plugs work? I understand that you just plug them into the flasher, but do we need them on our trucks? Do they just reverse the polarity of the flasher and the turn signals?
Eightyfive Flareside
Electrical Systems/Wiring
Nov 18, 2023 06:03 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 27, 2020 04:37 PM
joninflorida
Feb 14, 2019 12:52 PM
Supercab
Aug 17, 2006 06:00 AM
mikedeason
Feb 11, 2006 10:10 PM
