Injectors or what else
Old Jun 16, 2024 | 01:48 PM
out of answers's Avatar
out of answers
2nd Gear
Angry Injectors or what else
Hello all, I am a newbie on here so bear with me. I am having a problem with my 2000 f250 2x4 7.3ps, truck has 285,000 miles on it so I decided to replace injectors truck is bone stock put the 2,4,6,8 injectors in first took truck for a drive 1/2 mile from home it throws cel starts terrible no power turns out IDM took a crap so I ordered one from Gomers took a week to get it so in the mean time I changed 1,3,5,7 also changed the GP and Valve cover gaskets all Motorcraft while GP were out turned engine over by hand several times to clear cylinders. Engine turned over fine no hangups so I connect all the harnesses, and batteries and tried to start it several times 6-7 on the last attempt it hydrolocked and I heard a gurgling sound from upper engine .I failed to mention it has hydrolocked 4 times this truck alway started very easily only reason to change injectors intermittent misfire and no codes. Looking for helpful suggestions not smart a#$ comments TY PS The truck has been down for several weeks due to constant rain not allowing me to work on it
Old Jun 16, 2024 | 01:51 PM
Tpayne621's Avatar
Tpayne621
What injectors did you replace them with?
Old Jun 16, 2024 | 02:13 PM
out of answers
2nd Gear
They are stock reman from Peak fuel injection
Old Jun 16, 2024 | 07:13 PM
97-psd's Avatar
97-psd
Remove glow plugs, crank it to empty cylinders. That should tell you which cylinder had fluid. Check that injector to make sure it is fully torqued down.
53fordman1
Sep 26, 2020 12:40 AM
Mikethezipper
Apr 30, 2020 10:34 PM
Nudnik
30
Jun 7, 2018 04:05 PM
charger6t9r
Sep 17, 2013 08:26 PM
bassproguy07
Sep 25, 2007 07:05 AM
