1992 F150 302 - Won't start with key fully turned.
Old Jun 16, 2024 | 09:51 AM
adjustments's Avatar
adjustments
Trailering
Hey, I have a little problem going on, not life threatening or anything just annoying.
Whenever I go to start the truck, I have to find kind of a "sweet spot" with the key that is before a full crank. It feels slightly erratic as far as positioning, and sometimes has to be a VERY precise spot.
Could this be a problem with the Ignition Lock Cylinder? How would I go about testing for this? No related codes when I jumped the test connector either, just 1-1 KOEO and 1-3 KOER.
Thanks!
Old Jun 17, 2024 | 08:38 AM
1Butcher's Avatar
1Butcher
Won't start or crank? Big difference.
Old Jun 17, 2024 | 02:11 PM
adjustments
Trailering
@1Butcher I suppose I mean start? The engine fires up and runs fine, the key just has to be in a small awkward spot before full engagement as opposed to just turning the key til it won't turn anymore.
Old Jun 17, 2024 | 04:54 PM
adjustments
Trailering
Also, I replaced the Ignition Lock Cylinder b/c it was under warranty, didn't fix the issue.
Old Jun 18, 2024 | 09:04 AM
1Butcher's Avatar
1Butcher
I'm lost on your wording.
The engine cranks but does not run, right?
You need to hold the key in a certain while the engine is cranking for it to start, right?
If the engine is cranking and does not want to run, it's missing fuel or spark. Maybe both. Pick a system and find out what is missing.
Old Jun 18, 2024 | 09:17 AM
rla2005's Avatar
rla2005
Try starting the engine with the shifter in the Neutral position. If the "sweet spot" issue is resolved then check the two shift cable connection torx screws near the base of the steering column. Those are known tho loosen up.
If the problem remains you could have a failing ignition switch, lower steering column on the side, or the nylon ignition switch actuator is failing (also a common issue).
Old Jun 18, 2024 | 02:34 PM
adjustments
Trailering
@1Butcher Sorry if I was unclear. The engine runs fine, and it's not cranking or attempting to start while I fish for the sweet spot. It's binary, either it cranks and starts running when I hit the spot, or it is doing nothing.
@rla2005 My truck is a manual transmission (should have specified, my bad), so I'm not sure if the shift cable fix applies to me. I'm thinking you're right about the nylon switch actuator.
Old Jun 18, 2024 | 02:43 PM
rla2005's Avatar
rla2005
Having a manual transmission would eliminate the shifter screws/MLPS from the start circuit for sure.
Old Jun 19, 2024 | 01:27 PM
wwhite's Avatar
wwhite
Clutch switch/neutral safety switch?
mortonarts
1997 - 2003 F150
49
Sep 28, 2024 02:05 PM
danwelle
2009 - 2014 F150
Dec 12, 2016 08:01 PM
NMUF-150
Jan 10, 2008 01:31 PM
mikefox670
1997 - 2003 F150
Mar 2, 2005 07:36 PM
coplin
Sep 11, 2004 04:05 PM
