Transfer case question
Old Jun 13, 2024 | 10:51 PM
Rgarcia's Avatar
Rgarcia
1st Gear
I have a 1985 F150 4 x 4 shorted with a 300 6 cyl. And MT 4 speed . Can I put an C6 AT in place of the MT 4 and use the same transfer case?
Old Jun 14, 2024 | 07:05 AM
Franklin2's Avatar
Franklin2
Yes. All Ford transfer cases will bolt up to all Ford 4x4 transmissions. Just make sure the c6 is a 4x4 version. The c6 may be longer than the 4 speed, so it may require some modifications to make everything fit, like shorter and longer driveshafts. If you have a donor truck with the c6, you will have a lot of the small parts you need. If you have a donor that is a shortbed also, you will have the rear driveshaft you need.
jthorngate3
WTB - Parts & other
Jan 22, 2014 02:50 PM
Crazy Canuck
Offroad & 4x4
Aug 30, 2002 04:05 PM
CUWaldo
Dec 11, 2001 07:15 PM
