HELP!!! SBC Engine casting decoding
Old Jun 13, 2024 | 06:06 PM
dferrell5's Avatar
dferrell5
Hoping a few of you can verify what I see with my SBC engine casting numbers, I'm reading 3970014 which should be a 1970-1973 350 SBC. Anyone seeing anything different or have I lost my mind, my brother swears that is not what he sees. All help appreciated in advance.
Old Jun 13, 2024 | 10:47 PM
mtflat's Avatar
mtflat
I make it S970014
Old Jun 13, 2024 | 11:05 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Originally Posted by mtflat
I make it S970014
I see an "S" sort of, but it does look like a "3" if you look closely. The "1" is kind of wonky.
Old Jun 14, 2024 | 06:53 AM
avf100's Avatar
avf100
There is a tab on the front of the block right below the rh cylinder head. There should be an ID code stamped onto that tab that can be decoded to identify what it is.
Old Jun 14, 2024 | 06:54 AM
avf100's Avatar
avf100
Old Jun 14, 2024 | 11:25 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
With 4 younger brothers I can understand you don't want yours to be right but if he says he does not read what you posted, he is correct. I also read the S9 number. As far as Effie's photoshop, sure you change any number if you add and omit part of the casting.
Old Jun 14, 2024 | 10:24 PM
dferrell5's Avatar
dferrell5
If it is indeed a S, then what is it. When I look up the codes, I don't see anything starting with an S. Anyone got any ideas?
Old Jun 14, 2024 | 10:28 PM
dferrell5's Avatar
dferrell5
I took the picture so no photo shop or numbers omitted, the picture captures all the casting numbers there. When I look up SBC casting de-coding numbers, none start with an S hence I thought it must be a 3. Do you know any sight where I can find casting codes that may be helpful?
Old Jun 14, 2024 | 10:47 PM
avf100's Avatar
avf100
Did you look for the numbers on the front tab like I showed you?
Old Jun 14, 2024 | 10:50 PM
dferrell5's Avatar
dferrell5
I will look for them first thing in the morning. They are on the drivers side or passenger side in front of the cylinder head?
Old Jun 14, 2024 | 10:57 PM
avf100's Avatar
avf100
Passenger side...right below the cylinder head. You will need the ID that starts with a letter.
like the example starts with an F.
Hopefully it hasn't been ground off.
Old Jun 15, 2024 | 06:58 AM
EffieTrucker
64f1002017
16
Mar 30, 2024 12:05 PM
lvin4jc
Mar 3, 2024 06:49 PM
1986ed
Feb 10, 2023 11:11 PM
72Heirloom
16
May 8, 2022 07:12 AM
TheWiz427
May 31, 2003 09:00 PM
