2017 f250 6.7 king ranch throwing p24c6 code
Old Jun 12, 2024 | 09:38 PM
17alumaduty6.7's Avatar
17alumaduty6.7
8th Gear
My truck is throwing a P24C6. The thing is already deleted and tuned. Is this an issue with the tune or how it is deleted or is there something else going on? I am third owner and I was not the one who deleted it.
Old Jun 13, 2024 | 07:03 AM
F250_Super_4X4's Avatar
F250_Super_4X4
This code on a deleted truck means that you have a short in the plug and most likely blew a fuse. Recommend removing the harness from the ECU and adding a plug.
Old Jun 13, 2024 | 12:38 PM
17alumaduty6.7
8th Gear
Do you know what fuse I should check?
Old Jun 13, 2024 | 01:12 PM
F250_Super_4X4
Could be a bunch of them but it will be in the engine bay fuse box if one is blown. I wouldn't change it until you disconnect the harness and insert the plug though
Old Jun 13, 2024 | 01:15 PM
17alumaduty6.7
8th Gear
Okay when you say disconnect the harness which one do you mean and where?
Old Jun 13, 2024 | 01:51 PM
F250_Super_4X4
Old Jun 13, 2024 | 02:02 PM
17alumaduty6.7
8th Gear
Okay I will try this and let you know what I find. Thank you
Old Jun 13, 2024 | 06:04 PM
17alumaduty6.7
8th Gear
Unplugged connector and still have the code. Didn’t see any obvious fuses blown but I don’t know what ones to check.
Old Jun 14, 2024 | 07:42 AM
F250_Super_4X4
So you unplugged the connector, cleared the codes, started the truck and the code is still tripping? That theoretically is impossible...
Old Dec 31, 2024 | 02:13 PM
taylors98's Avatar
taylors98
1st Gear
Did you ever fix this issue? Having the exact same issue , unplugged the harness & still throws the code after it’s cleared
bigskoolian
Jan 28, 2024 10:48 PM
wb6anp
Sep 27, 2016 08:25 AM
Marine5811
Paint & Bodywork
Dec 28, 2010 11:59 PM
weekendwarriorfsw32
Oct 17, 2009 04:49 PM
sluggo2u
Feb 7, 2003 12:06 AM
