6.7PSD Autopsy
Old Dec 28, 2024 | 08:32 PM
FishOnOne's Avatar
FishOnOne
Old Dec 28, 2024 | 10:00 PM
JoeUser's Avatar
JoeUser
Interesting video, thanks. Very cool to see how everything gets exposed, all the way down to the bare block.
Oh, the video title is a little misleading; death by water ingestion is not specific to just the PS 6.7. Any engine can be destroyed the same way.
I think his analysis of how it happened is likely correct. Someone drove into water deep enough to suck enough water into engine to kill it. That one piston rod was gnarly...
Old Dec 29, 2024 | 12:13 PM
FishOnOne's Avatar
FishOnOne
I agree...
Old Dec 30, 2024 | 11:31 AM
The Bone's Avatar
The Bone
Does Ford not have a corner on the bolt market?
Old Dec 30, 2024 | 12:47 PM
acdii's Avatar
acdii
Unless its an early HO, that happened to a few from the turbo leaking coolant.
Old Dec 30, 2024 | 04:14 PM
Superdave71's Avatar
Superdave71
Those valve cover/intakes are HUGE castings!!
Old Dec 30, 2024 | 09:18 PM
acdii's Avatar
acdii
Did anyone pay attention to the gear sprocket on the crank?
It was TIG welded. that engine has been worked on previously. Too bad that cylinder got cracked, otherwise perfectly rebuildable. I don't know if those can be sleeved, of they can, that engine wasn't in bad shape, fully rebuildable.
Old Dec 31, 2024 | 10:43 AM
Superdave71
He definitely caused a fair amount of damage waiting to tear it down. Did I miss glow plug removal? Once he pulled the heads he pointed out the holes for them, but I don’t recall their removal.
Old Dec 31, 2024 | 11:35 AM
acdii's Avatar
acdii
Yes, he shows all 8 being pulled. One of them was carbon soaked so bad he had a helluva time getting it out.
Old Dec 31, 2024 | 12:35 PM
longhaultransport's Avatar
longhaultransport
Those were injectors not glow plugs.
Old Dec 31, 2024 | 04:34 PM
Maxium4x4's Avatar
Maxium4x4
Just started watching and wondered if anyone here had posted the video....... Yep, anything can be destroyed.
Old Dec 31, 2024 | 04:37 PM
Leardriver's Avatar
Leardriver
I watch most of Eric's videos, and he usually is on the right track about the cause of the failures.
Old Dec 31, 2024 | 07:28 PM
Tib's Avatar
Tib
Watching a video of a full rebuild of one (I was bored) its insane the torque pattern for one head.
Old Dec 31, 2024 | 07:36 PM
FishOnOne's Avatar
FishOnOne
I think a saw a little available space for one more 8mm to hold down the water pump.
Old Dec 31, 2024 | 08:19 PM
JoeUser's Avatar
JoeUser
No kidding! I had no idea that the primary water pump was so freakin' huge...
