Sponsored by: Real Truck
power steering issue -- hydroboost?
Old Jun 10, 2024 | 11:06 AM
MotoStu's Avatar
MotoStu
Hi all. I've tried searching but haven't yet found my exact symptoms. My brakes work well, and steering is normally fine too...except when I have the brakes applied. Steering assist seems to go away when I press the brake pedal. Does that indicate some kind of issue with the hydroboost? If so, is it something that can be repaired (eg, some kind of check valve) or does it require changing the unit? My truck is a later 2004 F250 with the 6.0.
If there are any tests I can do to find root cause, let me know.
Thanks,
Stu
Old Jun 10, 2024 | 12:14 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
That is an indication that the Power Steering Pump is on the way out.. Or may just need servicing.
Old Jun 11, 2024 | 02:50 PM
SteveH-CO's Avatar
SteveH-CO
Evacuate all the fluid from the PS system and refill with the correct fluid and see if that helps. You may need to do this twice to get all the old fluid out of the system, with a short drive between drain/refill cycles.
Old Jun 11, 2024 | 05:18 PM
MotoStu's Avatar
MotoStu
Thanks. Changed fluid a year or so ago when I put a Red Head steering box on it, so don't think it's a fluid issue? I used some bottles of Mercon V I had leftover from my old F150.
maistroyoda
Jan 16, 2026 10:55 AM
Obs7.3Powerstroker
13
Apr 15, 2019 10:28 PM
Melissa29
Aug 28, 2015 04:21 AM
IHateCommieCars
Jun 15, 2015 04:31 PM
Olddog66
Apr 27, 2008 07:23 PM
