New Camshaft Idle Issue
Old Jun 5, 2024 | 12:34 PM
roliver17's Avatar
roliver17
5th Gear
I recently installed a new camshaft (Comp Cams 35-512-8), reccomended valve springs, ford performance lifters, and longer pushrods that were needed in my 1993 f150 5.0 4x4 with an aod trans. When I first start it up it idles fine and will idle fine all the way to warming up. However the moment you give it gas and let off of it, it starts to idle rough (surging). It almost dies and then revs up back up. I give it gas and the engine runs fine. Then I let off the gas and get that very rough idle. Temperature and Oil Pressure are good. I set the timing to 12° BTDC and still have the issue. This camshaft is supposed to be speed density friendly. I'm not too knowledgeable with these ford efi systems so any help would be appreciated.
Old Jun 5, 2024 | 01:14 PM
Scndsin's Avatar
Scndsin
I've run the 512 in my 5.8 for quite some time. GT 40 heads, .30 over, flat-top hypers, Cobra rockers, modded intake & factory injectors, etc.
Idle never was an issue nor off idle tip in.
What was the reason for longer push-rods?
You did a good job stabbing the distributor & setting base timing, spout pulled ?
Try going 10*
Old Jun 5, 2024 | 01:21 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I was wondering the same thing. When I put a Comp 35-349-8 camshaft in the ‘89 302 and checked it with a pushrod tool it was the same length as stock.
Old Jun 5, 2024 | 01:22 PM
Hit Man X's Avatar
Hit Man X
Firing order correct? How is fuel pressure? O2 plugged back in also?
I only as FP as I chased idle surge with that for a while on separate vehicle.
Old Jun 5, 2024 | 02:48 PM
roliver17's Avatar
roliver17
5th Gear
You did a good good stabbing the distributor & setting base timing, spout pulled ?
Try going 10*
I have stamped steel rockers and stock e7 heads. When I torqued the rockers down to 23 ft/lbs they were still extremely loose on the pushrod. I found a post on here where a guy had this problem with this cam and I got 6.3" pushrods over the stock measured 6.248". That seemed to torque correctly.
What's the spout? I dont think I had that pulled.
The weird thing is if I let it idle up to temperature there is no problem. However once you give it throttle at temperature it runs fine until you let off the gas. I'm running open headers right now, the o2 sensor is plugged in but not reading exhaust (just dangling there). No check engine light (it's not burned out).
I'm thinking I need to bypass the IAC or something.
Old Jun 5, 2024 | 03:23 PM
R&RFord's Avatar
R&RFord
The O2 sensor is your problem.
Old Jun 5, 2024 | 03:27 PM
Scndsin's Avatar
Scndsin
The spout is a jumper plug over by the diagnostic connector in the drivers side corner under the hood.
You pulll the jumper (stopping the computer from adjusting the timing), set timing to 10* BTDC, tighten down the distributor & re-install the plug.
Old Jun 5, 2024 | 03:28 PM
roliver17's Avatar
roliver17
5th Gear
Is it possible to leave unplugged until I get it to the muffler shop? Thanks for the help.
Old Jun 5, 2024 | 03:46 PM
R&RFord's Avatar
R&RFord
Make sure you correctly set the base timing with the spout connector removed before you drive it. Too much base timing will result in detonation.
Driving it without exhaust or O2 sensor may be possible but not advisable. I expect the computer would be in "limp" mode and driveablity would be impacted. Never tried it so can't really speak to how it would go.
Old Jun 5, 2024 | 06:49 PM
Conanski's Avatar
Conanski
Are you saying the truck has no exhaust on it? If so that is your problem.
Old Jun 5, 2024 | 07:30 PM
R&RFord's Avatar
R&RFord
Just FYI your noticable problem starts after warm up because that is when the computer starts looking at the O2 sensor to adjust fuel trim.
Old Jun 5, 2024 | 09:34 PM
roliver17's Avatar
roliver17
5th Gear
Yes sir it was open headers. I just managed to get my y pipe bolted up and have a couple bends out the side so should be an improvement and o2 sensor can read now.
Old Jun 5, 2024 | 09:36 PM
roliver17's Avatar
roliver17
5th Gear
I figured it something along those lines. I have a y-pipe on it now with the o2 sensor. I also discovered while I was under there I forgot to plug in the knock sensor so that's back on as well. I plan on getting it timed with the spout unplugged tomorrow morning.
Old Jun 6, 2024 | 12:21 AM
TobyB's Avatar
TobyB
If your oxygen sensor can't get an accurate exhaust reading, unplug it.
It will read free air, otherwise, and the computer will try to lean the engine out,
which will make you go very lean, but the oxygen sensor will still be reading lots of oxygen...
Yes, you'll go into a limp strategy, but that's better than an erroneous sensor reading.
t
23XL
Jan 24, 2024 05:10 PM
Mike8623
Aug 2, 2011 12:52 PM
REXHOUND
Feb 4, 2011 06:09 PM
tpolley
Sep 10, 2008 04:46 AM
brisk_truck
Jun 6, 2007 02:32 PM
