Power Valve Differences
Old Jun 5, 2024 | 11:10 AM
kr98664's Avatar
kr98664
Boys and Girls,
I recently had a little trouble with my truck running excessively rich all of a sudden. I found the power valve had come loose on the 2150 (2bbl) carb. The power valve is located on the bottom of the carb, between the idle mixture screws, inside the cover shown in the middle of this picture:
I tried to reinstall the power valve, but the threads would barely catch. After some serious headscratching, I found some variations in the length of power valves from different manufacturers. Here is the critical dimension X, from the ends of the threads to the gasket surface:
Here's the removed power valve, showing the shorter .4155" dimension:
Here's the longer version, at .4920":
The difference is only .076", but it made all the difference. Sorry, I don't have records for which manufacturer made which version. But if you have to replace one, measure it first to avoid the short version. Avoid a thick gasket, too, for maximum thread engagement.
Old Jun 5, 2024 | 11:37 AM
Max Capacity's Avatar
Max Capacity
Interesting. Been many years since I took apart a Holley.
Did you see some of the "related threads" below ?
The one in the "small bock V8" forum looked interesting. I never knew about the marking #'s on the valve.
https://www.ford-trucks.com/forums/1...ft-2150-a.html
Old Jun 5, 2024 | 05:30 PM
FuzzFace2's Avatar
FuzzFace2
Also Holley PV come in 2 different types and gaskets that go with them.
By different type it is the openings
And that is only the single stage valves
Dave ----
Old Jun 6, 2024 | 08:28 AM
Bronco638's Avatar
Bronco638
Up in the sky! Is it a Bird? Or, a Plane? No, it's Power Drop Man!!
Wait, wrong thread................. nm..............
vc10786
Nov 15, 2023 04:07 PM
fiveofsevin
Jan 29, 2023 09:31 AM
woody367
Nov 6, 2022 03:16 PM
Mountain_anderson
Jun 17, 2022 09:41 AM
scottlane
Sep 30, 2009 10:43 PM
