No crank
Old Jun 2, 2024 | 11:22 AM
Hooligans76supercab's Avatar
Hooligans76supercab
Trailering
No crank
Hi i have a 76 f100 with the 360 in it, I recently went to start it and am getting nothing no clicking or anything. I have power from the battery and a new starter is on there as well, I can jump it from the solenoid and it starts and runs great. Could this be caused by a faulty ignition switch? when i remove the ignition wire from the solenoid and check for volts I'm not getting anything.
Old Jun 2, 2024 | 11:33 AM
dlburch's Avatar
dlburch
could be faulty switch, or faulty/misadjusted neutral start switch. Try wiggling the gear selector while attempting to crank, or put it in neutral....assuming you have an automatic...
Old Jun 2, 2024 | 11:37 AM
FuzzFace2's Avatar
FuzzFace2
First read this and run the test as it will point you where you need to look for a fix
https://www.ford-trucks.com/forums/1...w-starter.html
Now you have me a little confused when you say
Are you getting any lights inside as this can help us help you.
Then power from battery to where????
Then something about jumping the solenoid and getting it to run.
Did you jump from large stud to large stud or battery to the small stud with the "S"?
Also does the truck have a auto or manual transmission?
So I dont think it is a battery issue if it started and ran but need more info.
Dave ----
Old Jun 2, 2024 | 11:47 AM
Hooligans76supercab
Trailering
Yes lights are working and the battery is new and so is the starter. I jumped it from the large stud to the small stud that the ignition wires connects to.
Old Jun 2, 2024 | 11:52 AM
Hooligans76supercab
Trailering
Thank you just tried that and to start it from neutral still nothing
Old Jun 2, 2024 | 01:10 PM
FuzzFace2's Avatar
FuzzFace2
Ok so the small stud is not getting a signal when the key is turned to start.
You not have to back trace or it is forward trace
You will need to know what color the wires are for this part.
At the IGN switch test for power on the signal wire from switch to NSS
If it has power move to the NSS / no power replace switch.
At the NSS check to see if that wire still has power at the NSS when turned to start.
No power wire is broken somewhere / power wire is good.
At the NSS check if there is power out going to the solenoid.
No power out bad NSS switch / power out check for power at the solenoid.
Solenoid no power on the wire to the small stud bad wire / has power bad solenoid.
Dave ----
Old Jun 3, 2024 | 10:18 AM
daysgone's Avatar
daysgone
Trailering
I believe you fellas may be jumping in the deep end first. I would ohm out the solenoid and make sure your wiring from the coil is present. I had a '67 that I jump the solenoid back in the day until i had the time to get a new solenoid? Becareful on older trucks like my '67, it had no safety switchh annd if in 2nd - 3rd gear would take off down the road if it was in gear and you jumped the solenoid ;-)
Old Jun 3, 2024 | 10:27 AM
dlburch's Avatar
dlburch
he stated that he provided power to the ignition post on the solenoid and it cranked...which proves the solenoid coil is fine.
Old Jun 3, 2024 | 11:05 AM
Hooligans76supercab
Trailering
Thank you all as it turns out it was the neutral safety switch they had it zip tied in place and tucked under the dash and the zip tied must of moved as i slid it back a little and it fired right up
Old Jun 3, 2024 | 06:49 PM
Greaser007's Avatar
Greaser007
My '77 just a few weeks back did nothing. Zip, nada.
My first thought was to check the connections at the little prongs on the solenoid where the hot wire from ignition pushes on.
Sure enough, the connection was loose, so I simply re-crimped the female end terminal on the wire, and Presto.
Back in business.
CDLUX
Jul 7, 2015 10:03 AM
Farmer Kelly
Jul 5, 2015 11:07 PM
bigred66
2004 - 2008 F150
Sep 30, 2011 11:42 AM
1959_f100
Dec 17, 2008 01:04 AM
podman152
Nov 29, 2004 06:57 AM
