Engine vibration when not moving
Old Nov 26, 2003 | 09:21 PM
Dyerstown's Avatar
Dyerstown
Finally got the rebuilt 460 running! There is a vibration while breaking in the cam with the truck in Park. I got a short block rebuild, and put the harmonic damper and flexplate from another 460 on it. How can I tell whether either engine is internally or externally balanced? Does an engine number somewhere on the block tell what year it is? If so, where is it located?
What about the flexplate--can it be incorrect, or installed improperly? Thanks for your help (again!)
Old Nov 27, 2003 | 12:16 AM
walt80's Avatar
walt80
You can tell by the year it was made.If it is a 78 or below it is internally balanced. It is on the side of your block. I have a 79 and there is a hatchet shaped balancer behind the harmonic balancer. I was wondering the same thing about my flexplate but I could only get it to go on one way.
Old Nov 27, 2003 | 12:19 AM
walt80's Avatar
walt80
I almost forgot to tell you, if you would have a 79 block it would say D3 or a69 block it would say C3. D is for 70s blocks and C is for 60s and soforth.
Old Nov 27, 2003 | 12:20 AM
walt80's Avatar
walt80
Sorry Im a little tired, I meant to sayD9 and C9. Im typin' before Im thinkin'.
