Clutch Identification Help Needed
Old May 31, 2024 | 08:35 PM
Lukem H's Avatar
Lukem H
8th Gear
I’m looking to replace the clutch in my 1972 f-250 factory 4wd with an NP435 and a 360 FE. I need to know whether to order a standard lever type clutch or a diaphragm clutch. Any way I can tell without opening the whole thing up? Thanks
Old Jun 2, 2024 | 11:10 AM
FuzzFace2's Avatar
FuzzFace2
The only way to know is if you and look in there thru the fork to see what you got.
But I dont think it makes a difference other than how much it take to push the clutch pedal.
I say this because the lever type you got to have a strong leg to push the pedal the finger type is easy on the leg.
Beside being easy to push it is also easy on the linkage& clutch bushings.
Most old school clutches used the heavy leg lever type but the newer school use the lighter leg finger type.
They both have the same clamping power.
Look at Center Force clutches, all they sell is the finger type.
Think it is the finger type I installed in my 81 F100 with a NP435.
I just asked the parts store for a clutch kit and that is what I got.
In my case I did not know the flywheel could be drilled for a 10" or 11" disc and I got the 10".
If I known I would have gone for the 11"
Been on the road over 5 years and over 28k miles with out any issues and I have pulled a 20' enclosed trailer a few times also.
Dave ----
Old Jun 2, 2024 | 02:09 PM
1browski's Avatar
1browski
My 72 f250 used the 11" as well. I ended up getting the parts from Rockauto.
Old Jun 4, 2024 | 08:58 PM
Lukem H's Avatar
Lukem H
8th Gear
Thanks
Thanks for the responses it helps a bunch!
SoCal-Bob
Aug 5, 2022 11:19 PM
Tbanks1382
Apr 29, 2021 01:16 AM
lincky92
May 11, 2020 06:01 PM
66crawler
Aug 20, 2012 07:38 PM
