410 stroker build
mom hoping to make a HP per cube and 450ft lb tq.
Most companies that sell them require a good core or they wont sell it.
I have a 410 in my 1976 Highboy.
It came out of a 1966 Mercury.|
I feel quite fortunate to have fond it.
It runs like a healthy 390.
I built around my cam and you plan to build off your 428 crankshaft so I get your I'm going 410 route as you already have one of the key parts.
I did 431ci. For pretty much the same $ you could go 445ci.
My Build info:
Stock-ish D2TEAA heads (I had some work done but retained the stock heads) Aftermarket heads will get you closer to your target.
4.080, so it's .030 over the standard 4.050 bore
Eagle Rod Stroker Kit P/N 15810 with 4032 Mahle -26cc inverted dome pistons
4.125" stroke
6.700" connecting rods
Comp Cams XE262H Grind (P/N 33-238-4) Xtreme Energy Hydraulic Flat Tappet Camshafts
1.509" O.D. Outer, .697" I.D. Inner Comp Dual Valve Springs
ProGear PG4018 Timing Chain
Pioneer 872056 Harmonic Balancer
Edelbrock Performer RPM P/N 7105 FE Intake Manifold
Now running Holley Sniper EFI
Now running Holley Sniper Hyperspark Distributor
Sanderson FF427-P Headers
My best dyno numbers were:
Carb
415HP @ 4400RPM
535ftlb TQ @ 3900RPM
FiTech (swapped to Sniper after 2 or so years)
415HP @ 4700RPM
530ftlb TQ @ 3700RPM
All in cost - A couple grand more than somethingclever estimated and that was pre-covid when prices were cheaper, but Los Angeles pricing, so yeah 8-11.5k is probably accurate.
My Build info:
4.125" stroke
Carb
415HP @ 4400RPM
415HP @ 4700RPM
I'm kind of thinking the Merc 410 is a tall block engine. Good for towing torque, but at the rpm where power is made.
I happen to have a '66 Merc 410 in a '71 F250 which I don't drive, and should sell.
From what I've read, the C4AE ? heads with the smaller exh ports are no Slouch for making torque.
When I'm towing, it is not flat and level, but All-Uphill, climbing up into the Sierra Nevada mountains in NE California, up to summits of 6,500 to 8,500 feet from down in the valley at 350 feet absl.
Therefore, my engine is not idling happily along flat ground in OD, but throttle plates are open and 4-bbl kicked in and running along happily at between 3,600 to 4,400 rpms depending on how long and steep the grade.
Don't forget, marine engines typically are running power-on at 4,400 rpms sustained in fast-water inboard jet boats.
So, I like your idea of the 262 Comp cam or an equivalent mid-range cam, I'm not sold on Torquer cams. just me.
My fun engine is a 385 series 429 with a D7 block casting.
This engine I sent to Auto Associates in Redding, California, and had him bore, balance, and stroke to 460.
I had him install the Crane mid-range cam and roller rockers and double valve springs. It likes to run.
I think whatever you do with your 360 will be a great improvement with the 428 crank. You'll be smiling.
