BANKS - ???
Old May 30, 2024 | 03:49 PM
Efftreefiddy's Avatar
Efftreefiddy
Trailering
Question BANKS - ???
I'm looking at a couple of upgrades from BANKS... wondering what everyone's thoughts are on:
Rear Diff cover
PedalMonster with iDash DataMonster
Cold air intake
Are they worth the money?
Where is the best place to buy from?
TIA
Old May 30, 2024 | 04:28 PM
senix's Avatar
senix
buy directly from Banks.
Dont need the cold air intake. Rear cover is nice but not sure it will do much.
Old May 30, 2024 | 04:57 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yup, CAI is a waste of money, diff cover is not much better, mostly for looks.
Pedal commander, eh...
I wouldn't fool with any of those items.
Old May 30, 2024 | 05:02 PM
senix's Avatar
senix
i use the idash and it is very useful in monitoring and pulling codes.
Old May 30, 2024 | 05:24 PM
SARDiverDan's Avatar
SARDiverDan
CAI probably won’t get you much improvement but there are a few who feel like they provide some benefit. I have the diff cover. I don’t really need the additional cooling as I sold my big trailer. With that said, the cover makes it easier to perform routine maintenance if you are the type that likes to change diff fluid more often than recommended in the owners manual.
I have an iDash and it’s convenient to look at various readings for the truck but these trucks have a tendency to go from zero to broke so having a few numbers on a dash pod may not matter very much. No idea about the tuner. I don’t think my truck needs one.
Old May 30, 2024 | 05:50 PM
speakerfritz's Avatar
speakerfritz
The idash saved me a lot of time and money
had some maint problems while on a 2000 mile trip. Ford was backed up in appts for 2 months for 100s of miles .
went thru some idash snap shots from when engine was fine…noticed a sensor deviation, ordered the sensor and problem was solved.
so if you get an idash and periodically snap shot key data for future reference the idash can be useful. But you can also snap shot useful data with free software such as odlink.
Old May 30, 2024 | 05:57 PM
Leardriver's Avatar
Leardriver
As soon as the Banks diff cover for the 11.6 is available, I will buy it just for bling. I have never had a diff problem in my life, and this seems like a solution looking for a problem, but they are blingy.
Old May 30, 2024 | 06:23 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Diff cover is just for bling.
CAI is a waste of money. Your stock airbox is already a CAI...
Old May 30, 2024 | 06:50 PM
Jorgem2's Avatar
Jorgem2
I got a cover for the drain plug and to feel better when I overload my rear axle.
also on the Banks site they had some unpainted ones on clearance
also found this coupon for 15% online
try adding it to the cart to see if it works still
code below
TUNDRASDOTCOM15
They had a good deal on Amsoil gear lube also
Old May 30, 2024 | 06:53 PM
acdii's Avatar
acdii
Pedal Monster and iDash yes, rest, no unless you want the bling. The PM will wake up the off the line stuff, and the iDash as mentioned is great for monitoring. For example I monitor my DF soot level %. Truck has said it was full many many miles ago, yet its only at 77% now. I manually regen when I know it will get done before I am done driving.
Old May 30, 2024 | 07:03 PM
dzdiggin'dude's Avatar
dzdiggin'dude
Nephew just bought a PM for his F150 and ordered through Amazon for faster shipping. Let me know how it works. Drive a F350 Cab Chassis and with the detune has a bad lag off the line.
Old May 30, 2024 | 07:35 PM
Efftreefiddy
Trailering
please delete for the noob
Old May 30, 2024 | 07:36 PM
Efftreefiddy
Trailering
code below
TUNDRASDOTCOM15
Hell yea it works! Thank you!
Old May 30, 2024 | 08:16 PM
450>350's Avatar
450>350
I don't think I'd worry about the iDash. The only thing it really monitors that matters is EGTs. But if you have a stock 6.7 your EGTs don't really get to crazy. Just add the temps to your gauges so you can monitor your coolant temp.
Old May 30, 2024 | 09:09 PM
Efftreefiddy
Trailering
That's the way I'm leaning... Removing the pod from the A pillar evertime it goes to the dealer would be a pain in the ****. And not to mention I would probably not be able to figger out how to use it anyway.
