Coolant flush
Old May 29, 2024 | 03:54 PM
AlewisIII's Avatar
AlewisIII
Coolant flush
Hello all I have a 94 f150 5.0 I need to replace water pump and wanted to do coolant flush, question is which better flush before pump change or after pump change. What is best and safest coolant flush that y'all know of. Also coolant is circulating in radiator water pump just started leaking from hole on top. And help greatly appreciated.
Old May 29, 2024 | 04:30 PM
oldhard47's Avatar
oldhard47
I did this in 2016 on my 1994 F150 5.0:
Flushed with two bottles of Prestone AS-105Y; then flushed with distilled water.
R&R a bunch of coolant system parts:
-water pump Duralast CWP-657 lifetime warranty
-thermostat - Duralast 15359
-heater hoses - ⅝ inch
-bypass hose
-upper radiator hose
-lower radiator hose
-all miscellaneous coolant rubber hoses
-Stant 10329 13lb levered radiator cap
-Prestone ethylene glycol AF2000 - 2 gallons - topped off with distilled water
No overheating before or after this maintenance.
Old May 29, 2024 | 04:41 PM
Jim_K's Avatar
Jim_K
Personally I would flush before the pump changeout, as who knows what that old crud can (will?) do to the impeller and seals.
If it helps, I'll be installing a new radiator in my '67 F250 when it arrives, and same thing- flush before the install. Give it a clean start!
Old May 29, 2024 | 06:57 PM
AlewisIII's Avatar
AlewisIII
Yep, I was thinking the same thing about the flush, thanks y'all for the info and parts# ....
Old May 30, 2024 | 10:21 AM
1Butcher's Avatar
1Butcher
Never buy a lifetime part from those box stores. Unless you like replacing them regularly. Lifetime means little if you have to do them every 6 months. Good OEM that will last years is better than a lifetime warranty part that might last months.
Beware that the mounting bolts may be seized and break. Have a plan B to replace the entire front cover, thermostat housing, and seized bolts.
Nick 99
May 18, 2024 10:04 AM
Frozen_Joker
Nov 19, 2013 06:27 PM
JUMBO_UTE
Feb 8, 2006 04:32 PM
firebug
Aug 25, 2004 04:07 PM
