AC Help. Correct pressures?
Old Jun 7, 2024 | 12:24 AM
  #31
FordTruckNoob's Avatar
FordTruckNoob
I would have preferred suction too but circumstances did not allow it.
Old Jun 7, 2024 | 01:38 AM
  #32
udsuth78's Avatar
udsuth78
I'm pretty sure there's quite a bit of fan performance hanging on blade design. Some are made for pushing and others for pulling. I imagine the double duty models are like most all in one whatever's, yeah they can push or pull but not really do either well. I know the math supports a pull design also but find it hard to believe that a fair bit of compensation can't be designed into a pusher.
Old Jun 7, 2024 | 08:17 AM
  #33
Lex2002's Avatar
Lex2002
My ECU and PHP tuner should be back from PHP (Power Hungry Performance) on Monday so I wont get to test the AC until then. (PHP was not talking to the ECU).
Anyhoo....this discussion is most curious. I replaced cooling fan clutch some years ago as preventive maintenance. Call me crazy. But only now am I realizing we dont have separate AC fans and yet Ive never felt a lack of cooling in the truck. I suppose that when its hot enough to need AC the engine cooling fan will be turning and pulling enough air. Lord knows its big enough.
Old Jun 7, 2024 | 08:19 AM
  #34
Lex2002's Avatar
Lex2002
Why not?
Never had poor cooling. Just the current on/off situation.
Old Jun 7, 2024 | 08:25 AM
  #35
udsuth78's Avatar
udsuth78
You must hail from a mild climate that or just dang lucky. I've replaced every piece of the AC system plus add fans and fender vents just to get it decent at idle in this` Oklahoma humidity.
Old Jun 7, 2024 | 08:30 AM
  #36
Lex2002's Avatar
Lex2002
Maryland. Wouldn't call it mild in summer. Maybe I'm just lucky or maybe it because I drive with no clothes on..
Old Jun 7, 2024 | 08:34 AM
  #37
udsuth78's Avatar
udsuth78
Must make for interesting traffic stops.
Old Jun 8, 2024 | 01:19 AM
  #38
JoshHefnerX's Avatar
JoshHefnerX
First thing I'd do is make sure the clutch is working - staying engaged and not slipping. If it's not holding fast it could play w/ your pressures.
Once that's for sure up to par, then amend the freon.
That being said, I had a car a few years back that would use a can every 6-9 mo it had a slow leak. And the way I would know it was time to top off, is it would start short cycling - the safety switches would override kicking the clutch in/out because I was marginal on my pressures. So I would get cold, and then warm, cold, warm. ect
Old Jun 8, 2024 | 01:28 AM
  #39
Wes444's Avatar
Wes444
Yup. If you can't see it, it ain't humid yet
Old Jun 9, 2024 | 07:59 PM
  #40
Lex2002's Avatar
Lex2002
Checked the gap. It's greater than 0.045 which is the thickest feeler gauge I own, which is larger than the max gap of 0.030 inches according to all data.
I removed the clutch and it only had one spacer installed which when removed didn't get me close to 0.030 gap. And the clutch service looks pretty chewed up.
Old Jun 9, 2024 | 08:09 PM
  #41
Lex2002's Avatar
Lex2002
This looks like the correct clutch but Rockauto doesn't appear to sell the pulley.
Should I, can I change the bearing without pulling the compressor off?
Old Jun 9, 2024 | 08:18 PM
  #42
JoshHefnerX
That looks pretty worn. Not sure on the pulley. I'll let someone else answer
Old Jun 9, 2024 | 08:52 PM
  #43
Lex2002's Avatar
Lex2002
Found the part number on another site and looked for it on Rock Auto. Includes the bearing. EDIT: NOT the correct part #.
Old Jun 10, 2024 | 02:45 AM
  #44
udsuth78's Avatar
udsuth78
Did you take the belt of and spin the pulley by hand? Did it run quiet and smooth? If so I'd leave the shim out and slap it back together. If you've already made up your mind to replace everything then yes the pulley can be removed with the compressor installed. You'll need a set of angled snap ring pliers and maybe a block of wood or rubber mallet.
Old Jun 10, 2024 | 07:41 AM
  #45
FordTruckNoob
If that clutch is so old and worn that removing the shim won't correct the clearance, you might as well replace the entire assembly.
Amazon Amazon
