Sponsored by: Real Truck
Low Blower Volume
Old May 26, 2024 | 07:53 PM
TeeBeeCee's Avatar
TeeBeeCee
1st Gear
Low Blower Volume
I have a 2012 F350 service truck. It came from Texas and you can tell it was around a lot of red dust. I just added AC refrigerant and the air is cold, but the volume of air coming out the vents is low, even though the blower sounds like it is blowing a lot of air. Any suggestions?
Old May 26, 2024 | 11:59 PM
ifrythings's Avatar
ifrythings
All the air goes through evaporator core, in very dusty/field type environments it isn’t uncommon for the evaporator to get plugged up solid with debris.
I’ve never tried cleaning one in the truck but there is probably someone on YouTube that can show you how, otherwise it’s remove dash, discharge and unhook AC, drain coolant and unhook heater core, remove HVAC box and pull the evaporator. At that point it’s probably worth just replacing it and the heater core for good measures.
fpt2
Oct 30, 2022 07:40 PM
ckscape
6.4L Power Stroke Diesel
Aug 21, 2012 12:37 PM
fireeater91
Jun 30, 2009 09:04 AM
gramschm
Arkansas Chapter
Apr 17, 2009 07:17 PM
shellyh1971
Aug 12, 2007 08:41 AM
