It dropped to about 1500rpm. That tells me that it was in overdrive at that point. I would then let off the throttle ever so slightly so I wouldn't keep accelerating and it would downshift back to what seemed like direct.
My guess as to what's happening is that when you roll into the throttle the torque converter is locking. When you back off a little it is unlocking. If that is what is happening, I think the TP sensor is not adjusted properly. It would be reading a lower voltage that normal if that is what's happening.
I will double check the TPS, but I don't see that being the case. It all worked fine before the swap and I didn't touch the TPS, but I will verify its good.
I did hook up the sensor for the brake master cylinder switch that I think unlocks the torque converter when you step on the brake? But its just hanging out under the hood because the vans master cylinder doesn't have a port for it.
I also hooked up the OD cancel button. It works as it should with no flashing or anything.
While I am in direct (OD cancel light on) the torque converter does the same thing. Unlocked a majority of the time until I roll the throttle on, then it locks.
So let me go a bit more into detail. When I went to look at the truck, the brake pedal stuck slightly, so slightly that the brakes wouldn't be applied, but the brake lights would stay on.
While test driving it, I noticed when the pedal was stuck, it would exhibit the same characteristics as it is right now (I have since learned that it's the torque converter being unlocked). When I put my foot behind the pedal to bring it all the way up, the torque converter would immediately lock.
On these trucks, is it normal for the torque converter to unlock as soon as the brakes are applied?
O
Now this makes sense. I know what's happening.
When the PCM thinks the brakes are on as indicated by the BOO (brake on off) circuit it will unlock the converter when the accelerator pedal is less than 10% depressed. Once the pedal is over 10% the BOO input is ignored and the converter can lock.
This seems to match what you are describing.
Yes, this description matches what I am experiencing exactly! I will get that hooked up first thing tomorrow morning and test it.
Before yesterday, I couldn't identify if it was shifting or unlocking/locking torque converter. Now things are making a pile of sense.
So I am looking into this this morning and things aren't making sense. From the factory, the BOO is designed to allow 12v through to pin 2 on the computer which tells the torque converter to unlock. Does that sound correct?
I don't have the switch hooked up, so pin 2 isn't seeing 12v from the BOO switch. However, with the engine running, pin 2 on the pcm is ready close to 10v. Is this correct? Should it read zero, or is the pcm putting the 10v out of pin 2?
With an open circuit and dozens of others energized close by your DVM is most likely reading an induced voltage, i.e phantom. Yes it happens in DC circuits to. Chased my tail many times. A high impedance DVM will frequently lie to you in this scenario.
If you use an incandescent test lamp it will most likely not illuminate.
If a test lamp does illuminate, that implies the internal BOO circuit is most likely using a pull up resistor.
So this raises more questions than it answers. Being “no voltage” there, this means that the torque converter should lock up soon after shifting into third and forth if this circuit was the problem?
I tested the TPS and it is perfectly in spec.
Anything else I need to look at? Like I say, it has to be a wiring issue because it worked find before removing it from the truck.
Look at the EVTM manual for the brake light circuit. Wire yours EXACTLY as shown. The computer is expecting a high or low. An open circuit will create havoc because of an undefined state.
