NP205 drip from access panel
Old May 26, 2024 | 03:48 PM
Deadbuck's Avatar
Deadbuck
The 3 lower bolts on the NP205 rear access plate have a super slow leak. I tried backing out the bolts, adding thread seal and tightening back it slowed the leak way down but still has a super slow leak. Any other ideas or suggestions on how to get it to stop?
Old May 26, 2024 | 06:24 PM
Rubiranch's Avatar
Rubiranch
You might try black silicone.
Its made for oil.
Old May 31, 2024 | 04:08 PM
Deadbuck's Avatar
Deadbuck
Its made for oil.
As in RTV sealant? Should I put some on the threads? I haven't hammered down on the bolts yet. I could try torquing them some more also? Not sure the best approach
Old May 31, 2024 | 08:32 PM
tbear853's Avatar
tbear853
If you pull them out to seal threads after cleaning threads, might pay you to first drip drain the case.
If were mine, I'd just clean the outside off every time I service the transfer case lube. The 205 is a cast iron case, but that cover is aluminum and it has a bearing in the center.
ENCSDEI
Mar 28, 2009 07:59 PM
Smith76
Feb 22, 2006 02:36 PM
happy
Apr 8, 2004 12:27 PM
ethomps
Feb 19, 2004 01:14 PM
