Leak sealant
Old Mar 28, 2009 | 12:49 PM
ENCSDEI's Avatar
ENCSDEI
Leak sealant
I know this is not the correct way but I need to pass the TX state saefty ins. I have an exhaust leak at the adapter between the exhaust outlet flange and the bottom of the intake plenium. I know it is the gasket, however, the bolts will break when I take it apart and all else will go wrong, so what is the reccomended compound to spread along the seem to stop the leak? I was thinking some sort of liquid metal or JB weld?? Actually with the CAM I have in the engine I think with the low idle they think there is a leak due to the sound, but finding this leak it is hard to disprove them. Any suggestions
Joe
Old Mar 28, 2009 | 07:59 PM
91Bronc300's Avatar
91Bronc300
Try the same compound you use to seal holes in mufflers. It comes in a kit with a steel mesh you apply over the muffler hole first, then smear on the epoxy/plaster, whatever it is. Try that stuff. All it can do is just burn off and stink horribly after you've passed inspection.
