7.3 IDI Revival
My first order of business is what will I need to swap? If someone can list the differences, that would be greatly appreciated, here's some differences I noticed/saw talk of on other forums:
- Multi v-belt setup vs. serpentine belt
- Automatic vs. manual transmission
- Possible exhaust manifold differences?
- Possible oil cooler differences
- Motor mounts
- Oil pan / oil sump?
Sorry for the long-winded post. I would love a list of the things I will need to interchange (keep in mind I am switching an engine initially paired to an automatic to a manual) if possible, but any/all help is appreciated. Thanks.
oil pan you will have to see if it is different. you can use either belt setup, but the serpentine will probably be easier.
Thanks tjc, I plan to go over to the friend's shop where it's staying sometime this week and assess. I think I'll opt for the serpentine belt for simplicity's sake. I recall you mentioning that I may need some kind of bearing for the transmission when I drop the engine in since it originally was paired to an auto. Is that so? Here's your quote from the previous thead:
QUOTE=tjc transport;21134262]engine mounts may be different, i don't remember. i know the towers are different, but not sure on mounts themselves.
auto trans to manual trans, you will need to add a pilot bearing in the crankshaft snout before mounting the clutch assembly.
while it is apart, you should also consider doing a Luk clutch swap to get rid of the P.O.S. dual mass flywheel setup.[/QUOTE]
Is this pilot bearing not already found on my original engine? Or will I need to order this bearing?
I also remember you mentioning a Single Mass flywheel as opposed to a DMF, what are pros/cons there?
as for re using the old one, no because it need to be pressed in and out.
they are cheap, under $15 at rock auto:
https://www.rockauto.com/en/catalog/...t+bearing,1964
single mass flywheel with luk clutch kit is the way to go. plus it is a lot cheaper than DMF setup
$351 for a complete luk kit: https://www.partsgeek.com/fh77f81-fo...MaAt41EALw_wcB
compared to over $700 for just the flywheel last time i looked at the dmf setup.
I gutted that '90 that came out there, someone tossed a documented 70,000 mile truck man. Last oil change sticker from '01. Disgusting...but benefit for me.
Regarding the LuK SMF swap, I was looking on partsgeek for the link you sent tic which I appreciate, I want to make sure I order the correct kit. The part number for an '89 7.3 LuK kit differs from a '93 7.3 LuK kit. The parts look identical and the prices are the exact same, but they had different p/n. My question is do I want the '89 one since the new engine is from the '89 or do I want the '93 on since the ZF5 is from a '93. Would an '89 (assuming manual) even have been paired to a ZF5 or was it still a T-18/T-19 at that point (and does that matter for my purposes)? Sorry for the slew of questions, second vehicle in my collection, and first manual vehicle I have owned.
'89 7.3 LuK kit: 5329-05430134
'93 7.3 LuK kit: 5335-05430135
Anyway, sorry to derail!
i wonder if the part number difference on the luk clutch kit is for 11 inch and 12 inch clutch?
first year for the ZF was 88.
and my 88 has had a banks non wastegate turbo one it since it had around 400 miles on it.
it is a little over 492,000 miles and never opened up. and i would not hesitate to drive it cross country and back.
Don’t be sorry! Always cool to have more info and learn more along the way!
tjc, good to know regarding ZF intro date. I am new to manuals, I am guessing either an 11” or 12” clutch would work? I may give partsgeek/LuK a call and try to get more info (i.e. give them an idea of my scenario).
edit: 492k mi is pretty amazing. Hoping to get some real mileage outta this thing once I’ve got some time/money into it.
Today in my spare time I rebuilt the oil cooler from the truck engine. Things could have gone better, admittedly I should have taken more care but I was excited to get going and in my haste I neglected to find a proper damper for the aluminum housing on the filter side. The other side came off pretty easily, but I tussled with the filter side for about an hour, finally relenting to using a brass hammer and then a small steel deadblow hammer to give it some encouragement. I tried a torch as well but it didn’t do much due to the aluminum heatsink. Regardless, I got it all apart and used some 3/32 ER70S-2 TIG Filler to clean all of the crud from middle tubes. I have my replacement seal kit from doorman (which for whatever reason comes with 6 o-rings instead of the 4 that I removed), I ordered it a while back and probably would have ordered ford ones if I hadn’t been in a hurry to do so.
- Motor Mounts
- Exhaust Manifolds
- Oil Cooler (which was cleaned out and rebuilt with new o-rings and gaskets)
I have ordered the single mass flywheel kit from LuK, I opted for the '89 year model fit as on partsgeek a '93 was listed as a factory turbo (beefed up internals) and an '89 was listed as an aftermarket turbo. I didn't want to ruin the harmonics and opted for the '89 "aftermarket turbo" version since the engine is NA. Here is the PN for the LuK kit I bought on partsgeek.com: 07-225
I have a few questions:
- LuK kit comes with pilot bearing (not installed), what is the best way to press said bearing in if I cannot access a hydraulic press?
- Noticed a bearing that is currently on the input shaft (throwout bearing? release bearing? same thing different name?), it appears as though a new one is included in the LuK kit. The bearing sits just in front (closer to the bumper) of the fork coming off the slave cylinder. What is this bearing? How do I go about replacing it?
- Finally, I have lost the ignition keys. I have previously drilled out the cylinder, but I'm not looking to do that again, is there a tool I can get to pick the lock? I looked at Lishi, but couldn't find any for this model/year for the ignition. I have no problem breaking the ignition cylinder if need be, but I'd rather not drill it all out again. Please advise
Pulled the oil cooler off again and found the cooling passages were worse than anticipated (it appears to be a routine thermostat failure). Got them mostly flushed out and reassembled, will run it and use some radiator flush when we have it all back together. Water pump was nasty, luckily the sandblaster made light work of it and it will be reused.
Currently in the process of lowering it back into the truck. It seems almost impossible to line up the crank pilot bearing and the friction splines with the input shaft. I think it may be easiest to pull the trans and get the engine settled before bringing the trans over to it and bolting up. If anyone has any tips for mating the engine to the trans that might help, please advise.
