Ford ecoline e350 v8 Automatic Trans, 2006 model
Old May 26, 2024 | 09:39 AM
Kabir's Avatar
Kabir
1st Gear
Hello please can anybody help me and assist me with advice on my car? When it is in neutral gear and you press the gas pedal its rev high also of the gear is in reverse it's accelerate with good force but if the gear is on Drive and you press the gas pedal its accelerate heavily like the gear is in gear 2 or 3 instead of gear one kindly help me I'm frustrated thanks.
Old May 26, 2024 | 04:35 PM
Fomoko1's Avatar
Fomoko1
Hi and welcome to FTE.
I moved your post to this tech forum.
Old May 29, 2024 | 09:17 PM
lhoward1134's Avatar
lhoward1134
If you have an OBD2 adapter and FORScan, you can check and see what gear it's actually in. That is where I'd start. I'm sure others can give you more advice after that. For an adapter, you can get a Bluetooth adapter that will allow you to connect to your phone. With FORScan lite on your phone, you can then check a lot of issues.
Old May 29, 2024 | 09:53 PM
tabijan's Avatar
tabijan
Is the check engine light on? You might have a transmission fault limiting you to one forward gear.
Definitely get FORscan if you can but use a generic scanner if that’s all you have.
Sixto
07 E350 5.4 198K miles
Old May 30, 2024 | 09:30 AM
Wildman25's Avatar
Wildman25
Sounds like you have the tranny in "Tow/Haul" selection, Button on the end of the gear selector, lit is tow/haul, not lit, off, normal.
If not lit, just press the button see if it shifts normal, you can do it while driving
Nick_brooks89
New Member Introductions
Sep 29, 2021 10:36 PM
Noah Owenby
Aug 24, 2017 02:00 PM
Elgesman
Aug 27, 2014 11:02 AM
