2019 - 2023 Ranger Everything about the new 2019-2023 Ford Ranger.
Lifting options
Old May 25, 2024 | 11:49 PM
Squanto's Avatar
Squanto
Lifting options
I didn't see a forum for 2017 Rangers so I figured I'd post here. My truck is a super base model 2 door 2.2L diesel 6 speed. I ordered it this way specifically to get an 8ft bed. I would like to lift it a little.
I know it's common to add blocks to the rear end to lift it but the springs are under the axle so adding blocks would actually lower the bed.
I could use longer shackles but I'm a little leary of going that route and it wouldn't do anything for ground clearance.
Another option I've thought of is moving the springs over the axle. I've measured that to result in about a 6 inch lift which might be a bit much.
Any thoughts on these or what other options might I have?
Old May 26, 2024 | 05:39 AM
KingDeleted's Avatar
KingDeleted
The only thing that adds ground clearance is bigger tires - so if shackles work to get you bigger tires than you’re good. Does it have torsion bars in the front? Not sure anymore, the last Ranger I owned was an 04
jason867
Dec 23, 2023 09:10 PM
Blakshukvw
Nov 4, 2016 11:29 AM
wace_dawg
Sep 9, 2007 06:44 PM
78fordman
Feb 27, 2004 10:22 AM
Starratt04
Jan 29, 2003 08:27 PM
