tailgate removal
Old May 25, 2024 | 09:48 AM
ericeric's Avatar
ericeric
7th Gear
tailgate removal
Hello, I recently picked up a 2024 f350 Xlt with 360 camera, blis, and the power open tailgate, and I had a utility body installed on it, but I have the tailgate ajar indicator on the dash Does anyone have any luck disabling that in Forescan?the upfitter claims the ford software they have couldn't do it. I haven't picked up the truck from the upfitter, so I haven't hooked up to the truck yet with Forscan to see what options there are. Just wondering if anyone has found a solution yet.
thank you
Old May 25, 2024 | 10:01 AM
4wd6.7L's Avatar
4wd6.7L
I don't know, but would think there is some sort of tailgate delete cap or something that makes it think the tailgate is closed. They used to include a delete/cap kit in the glove box of these trucks
Edit- Based on this thread it ooks like the delete kit wasn't working.
https://www.ford-trucks.com/forums/1728800-2023-f-350-tailgate-removal-kit-part-number.html
Old May 25, 2024 | 10:10 AM
ericeric's Avatar
ericeric
7th Gear
There is a tailgate delete harness, but it seems to be very hit-or-miss if it works. There were a lot of people having issues with them; it seems, so I was hoping there was a more reliable forscan option.
Old May 25, 2024 | 02:38 PM
capt caper's Avatar
capt caper
It's in the glove box. Dummy plugs.
Old May 26, 2024 | 07:50 AM
mattymax's Avatar
mattymax
Unfortunately you’ll have to bring it into the dealer. The 24’s tailgate delete kits are having an issue and either need a software update or rewire on the harness
I just took mine off my 23’ no issue.
Old May 27, 2024 | 08:06 AM
ericeric's Avatar
ericeric
7th Gear
I got the truck back and deactivated the blis and cross traffic in Forscan with no problem. I poked around a bit, looking for anything to do with the tailgate, and didn't find any options in Forscan. They have the dummy plugs installed but I still get the tailgate open message when I start the truck. I guess I might have to bring it in at some point to have it addressed at the dealer.
Old Aug 30, 2024 | 11:48 PM
rustyshatz's Avatar
rustyshatz
4th Gear
can you tell me your exact year and model and trim? Did your truck have the fancy tailgate with power tailgate, camera for when tailgate was down etc?
Old Sep 5, 2024 | 12:03 PM
truckbuilder's Avatar
truckbuilder
4wd Low
The delete harness does away with all tailgate functions. I have the same issue with the beds I build and install. We reuse the harness for backup sensors, camera etc. There isn 't a way that Ive found to disable this message either.
Old Sep 5, 2024 | 12:09 PM
rustyshatz's Avatar
rustyshatz
4th Gear
not sure if you have seen this.
Old Sep 5, 2024 | 01:13 PM
B767capt's Avatar
B767capt
There is a long discussion here and someone has added 3 wires to the 2024 plug that seems to work.
https://www.fordtremor.com/threads/24-owners-who-removed-tailgate.18096/
Brandon606
Sep 16, 2020 09:00 AM
dualwheels66
Dec 9, 2007 07:30 PM
