Belt replacement
Old 05-26-2024, 08:31 PM
jimzpsd's Avatar
jimzpsd
jimzpsd is online now
Originally Posted by Overkill2
It reads 6303GSA-P
I'll be looking into this... THANKS.
Don't be surprised if the Timken bearings say CHINA,..... SKF, Bower BCA, National, etc. big names in the bearing industry but most are from...you know where
Old 05-27-2024, 09:49 AM
Overkill2's Avatar
Overkill2
Overkill2 is online now
Received 6,766 Likes on 4,927 Posts
Yeah I know...
I'm definitely going to source some because now that I bought that kit, I'll either re-lube the old bearings on the original idlers, found a video on how to do it after i started to research the bearings, after I check them, or buy a new set, then I'll have an extra set to swap out.. Thanks.
Old 05-27-2024, 12:30 PM
jimzpsd's Avatar
jimzpsd
Relubing the old bearings is bad.....you'll think you did them a favor but the mileage and wear is already there. Look at it as buying new shoes and re-using your old laces, it will work (for a bit) but will need to be replaced.
The following 2 users liked this post by jimzpsd:
Old 05-27-2024, 02:00 PM
Overkill2's Avatar
Overkill2
Haha yep right on...
Old 05-28-2024, 08:03 AM
Sport45's Avatar
Sport45
Sport45 is online now
Along the same lines, I cringe when I see videos of people popping the seals off brand new bearings and adding more grease in order to make them better somehow. Just another way to ruin a good product. The right amount of grease is already in there.
The following users liked this post:
Old 05-28-2024, 09:27 AM
Overkill2's Avatar
Overkill2
I'll post up the video where a guy re-oils sealed bearings without popping off the seals... uses a vacuum pump.
Old 06-09-2024, 02:11 PM
SDER1's Avatar
SDER1
SDER1 is offline
Video was ... interesting concept, and creepy (narrating voice). Thanks for sharing, but will likely just press for "new" parts when ready - have the belt and prepping to do soon as PM, @ 75k and 7 yrs old OEM original.
Old 06-10-2024, 07:31 AM
Overkill2's Avatar
Overkill2
Agreed... new bearings.. I will buy new bearings for the OEM set to keep as a spare on the truck now as I bought the Gates kit..
Firefighter 1406
6.2L V8
01-30-2022 02:08 PM
RRRAVEN
1999 to 2016 Super Duty
06-28-2021 07:15 AM
kennethpina
12-16-2010 01:19 PM
trapperon
1997 - 2003 F150
01-24-2007 09:35 AM
andy wick
09-28-2005 02:43 PM
Quick Reply: Belt replacement
