a/c cold to warm
Old May 23, 2024 | 01:31 PM
Mike713's Avatar
Mike713
a/c cold to warm
So my a/c will blow cold and fine for a while, but then after a while 'sometimes' it'll start blowing warm as if the compressor stopped. If I checked, the low side line will be warm/hot unlike cold and wet [from humidity] when running normally. Would this be along the lines of needing to add refrigerant or needing to let some out? I know it was overcharged at the end of last summer and some was taken out. I'm thinking it's still a bit overcharged.
2004 5.4
Old Jun 1, 2024 | 12:17 AM
tbear853's Avatar
tbear853
Had a car doing that once, was the evaporator freezing and becoming blocked, so I'd turn to vent and it would still cool air as the ice melted. Was a thermo sensor issue.
Old Jun 2, 2024 | 09:24 AM
steve(ill)'s Avatar
steve(ill)
you need to know the low and high side pressure before you do ANYTHING.
Old Jul 3, 2024 | 09:49 AM
Mike713's Avatar
Mike713
I know the high side pressure is higher than normal. I added a bit of freon and its better. Also wonder if barometric pressure has an effect.
Yeroc_Semaj
Michigan Chapter
Apr 19, 2022 09:26 AM
Corner Gas
Oct 26, 2013 09:20 PM
jccapri
23
Jul 28, 2013 08:47 PM
husker
Kansas Chapter
29
Jan 11, 2010 07:02 AM
