Cab Trim Piece
Old May 23, 2024 | 11:09 AM
edjunior's Avatar
edjunior
Cab Trim Piece
Hey all. I just noticed today a trim piece at the back corner of my driver's side roof is flopping loose. It appears to be attached using a rivet that is nestled beneath the edge of the window. So the only way to get to it is to remove the rear window. I am in the process of seeing if my extended warranty will cover it (dealer said no, window place they deal with said yes). In the meantime, I'd like to find some way to "tack" it down so it doesn't go flying off. Any ideas Below is the piece in question:
Old May 23, 2024 | 11:16 AM
4wd6.7L's Avatar
4wd6.7L
You should find some techniques used by others in here- https://www.ford-trucks.com/forums/1...ap-broken.html
Old May 23, 2024 | 11:18 AM
2008f250xlt's Avatar
2008f250xlt
Pretty common, black RTV
Old May 23, 2024 | 05:46 PM
honda250xtitan's Avatar
honda250xtitan
rtv, blue tape over night. welcome to the club.
Old May 23, 2024 | 05:57 PM
Texmudder's Avatar
Texmudder
Be sure to put some black RTV on the other side as well as preventative as it will break as well.
Old May 23, 2024 | 10:24 PM
edjunior's Avatar
edjunior
Good idea. I'll work on this the next couple of days. Thanks for all the replies.
Old May 24, 2024 | 07:11 AM
sbechtold's Avatar
sbechtold
I had mine replaced under warranty, on my 2017, when the rear window defroster failed. They replaced the window and the plastic trim pieces. The new plastic pieces look like new and the rest of the trim is 7+ years old and faded, so they don't match. But it's fixed.
Texaswilliam
Jul 17, 2020 06:15 PM
Moldylizard
1997 - 2003 F150
Oct 18, 2015 06:13 PM
zxsmyers
1997 - 2003 F150
Jul 15, 2009 10:36 PM
crossf-150
Paint & Bodywork
Oct 3, 2006 08:42 PM
Dave_Exp
1997 - 2003 F150
Mar 18, 2002 12:07 PM
