fuel heater
Old Nov 26, 2003 | 06:04 PM
F0rdF0rever's Avatar
F0rdF0rever
fuel heater
Im having problems with my fuel heater. The fuse keeps blowing in the cold mornings. Because of the dropping temps I will soon be unable to start without it. Ive looked on a few different web sites for the part but havent had an luck finding one. Anyone know of anywhere I can get one.
Thanks..
Old Nov 26, 2003 | 06:20 PM
emtabmm's Avatar
emtabmm
The only place I know of is at the dealer. It comes in the Filter housing. You might try a salvage yard..... Also remove the filter, look down inside and you can see the element, you may be able to reposition it so it does not contact body of housing and short fuse.....
Old Nov 26, 2003 | 06:52 PM
F0rdF0rever
Thanks for the advice. So what you're saying is I may have to replace the entire housing? And if repositioning the element doesnt correct the problem how much will I pay for a replacement?
Old Nov 26, 2003 | 07:12 PM
emtabmm's Avatar
emtabmm
Well the parts dept is closed so I am guessing the assy that comes with the filter, cap and heater is around $400.00, the heater is availble seperate but every one I have seen the housing has broken when taken apart(left hand threaded). Heater element is around $50.00.
beersy50
Jan 15, 2014 09:18 PM
fhafer
23
Dec 8, 2013 04:39 PM
jlo84truck
Oct 13, 2012 07:32 AM
Littlered08
General Automotive Discussion
Dec 28, 2005 10:23 AM
