I just found your site as I was looking on how to repair a raised roof that has to be leaking. I have noticed that the carpet in the back is wet a lot of the time. I am assuming that I have a roof leak. I am so clueless as to how to even go about a fix. I guess I could take it to the place where it was purchased from. The van is a Ford 2010, E250 handicapped conversion van. Any thougths would be welcomed.
Thank you
Thank you for your reply.
I think it is on the driver side mostly in the back by the battery box, although I have gotten a few drops of rain water on my left leg as I am driving in the rain.
The weld where the roof joins the A-pillar is a known leak point. Poorly sealed replacement windshield can leak. Debris in the cowl at the base of the windshield can block drains sending overflow into the cabin.
