upgrades
Old May 18, 2024 | 08:07 PM
lartross's Avatar
lartross
upgrades
I've spent a lot of money upgrading my 7.3. New 180/30 single shot injectors, new upgraded gtp 38 turbo, new hydra chip, high output hpop...mostly because I wanted to tow my 11k 5th wheel with less worry about egt's getting away from me and leaviing a smoke trail behind...but, also kinda' thinking I'd feel it in the seat of my pants when i got on it...that's always been something I appreciated about my old 7.3...it felt good in the seat of my pants when I pressed the skinny pedel. But, to be honest, it doesn't feel like I've got any greater performance at all. Of course this is all subjective, but, still....$3500 seems like it should make a noticeable difference, don''t you think?
Old May 18, 2024 | 08:22 PM
lartross's Avatar
lartross
It does kinda' sound like a runaway bosuns wistle...
Old May 18, 2024 | 09:08 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
BDP tunes specifically for those new injectors?
Got any details on the upgraded turbo?
Old May 18, 2024 | 09:23 PM
Kintla's Avatar
Kintla
Did you do up pipes and check for boost leaks? Air intake or exhaust? Hutch mod ? Any codes at all? I'd think with a new set up like yours would have a noticable difference in seat of the pants unless you have underlying unaddressed problems.
Old May 19, 2024 | 06:31 AM
lartross's Avatar
lartross
I no longer use bdp tunes...hydra tunes...it's a gtp38r.
Old May 19, 2024 | 06:34 AM
lartross's Avatar
lartross
bellowed up pipes and new intercooler boots..noticed the boost was pretty low...may need to turn it up to 30" or so, huh?
Old May 19, 2024 | 07:23 AM
udsuth78's Avatar
udsuth78
Tuning can honestly make all the difference. When I first got my injectors in the custom tunes that came with everything were... Slow is the nicest way I can think to put it. After some back and forth with that tuner I ended up going to someone else and honestly night and day difference.
Old May 20, 2024 | 10:15 PM
cjfarm11's Avatar
cjfarm11
Start with the basics. Check for boost leaks, fuel pressure, icp, egts…….etc. If all the basics are good then look towards injector issues, or maybe wrong tunes?
110 Motorsports
May 19, 2023 03:16 PM
96 OBS
19
Oct 18, 2019 12:16 AM
RhinoRidener7
Aug 15, 2017 01:45 PM
Courtney Williams
May 15, 2017 07:50 PM
brown 4x4
Appearance & Dress-Up
Jul 20, 2004 05:12 PM
