Door/Window Problem 93 Ford F150
Old May 18, 2024 | 07:57 AM
Fordication's Avatar
Fordication
Ok this happened yesterday. I was driving and it sounded like I hit something but I did not. Something in my drivers side door fell off. I tried to lower the window with the push button and it only went down a few inches then would not go back up. So I just pushed the window down and it went down easy. Then I push the up button and the window goes up no problem. I know I am going to have to take the door panel off and find the problem and fix it. Just curious, what do you guys think I am looking for. Oh and something is inside the door and clunking whenever I open or close the door. What part fell off and will I have to replace it? THanks
Old May 18, 2024 | 09:20 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Heres pic of whats inside
Old May 18, 2024 | 09:55 AM
Fordication
Hmm, I wonder what fell off and is sitting in the bottom of the door.
Old May 18, 2024 | 07:29 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Remove a couple screws, the door panel and stop guessing.
Old May 18, 2024 | 07:49 PM
McLeod's Avatar
McLeod
Sounds like the glass became separated from the metal channel (part #2 above) that the regulator slides through.
I just silicone-d the glass back in place and has lasted 20 plus years
Old May 18, 2024 | 11:31 PM
Fordication
I would love to. I am on a power plant job in Buffalo, Tx for the last 9 weeks and have 2 weeks to go. No access to my tools to take it apart and was just wondering if anyone has had this happen before. I will be home in a few weeks but then off to Indonesia for a month. I was hoping for that week off someone could give me some ideas but alas I think I have to figure it out.
Fordication
Something dropped and is sitting in the bottom of the door. Will figure it out soon I hope.
Old May 19, 2024 | 04:40 AM
manicmechanic007's Avatar
manicmechanic007
If you were to post a picture of the door panel and related parts
I would point to the retainer for the panel with the screw that comes down vertically from the pull
They used to some out and fall down inside the door
Agreed, you are liable to find the problem in seconds when you remove the panel
Good luck with it when you get off work
Keep that grid up
Thanks
Old Jun 10, 2025 | 04:21 PM
Fordication
The bar holding the window came loose. I repaired it.
Trent Racer
Aug 26, 2021 08:27 PM
benHaskett
Escape & Escape Hybrid
Oct 2, 2015 10:04 PM
tcparry
2004 - 2008 F150
Jul 24, 2007 05:57 AM
Push2Shv
Aerostar
Dec 21, 2002 06:25 AM
