79 F-350 300cid no start
Old May 17, 2024 | 01:17 PM
Ivo Morey's Avatar
Ivo Morey
1st Gear
Hey all, I've got a '79 F-350 packing the 300. It's worked great for as long as I've had it, but all of the sudden it seems to not want to start. It cranks totally fine, has decent oil pressure, and has spark (to a degree). I have tried starting fluid down the carb and that hasn't made any difference in not starting. I'll mention that I have a sneaking suspicion that the ignition control module (a circa 2012 NAPA one that came installed when I bought the truck) is malfunctioning because I believe water dripped on the contacts just before the engine stopped starting.
Old May 17, 2024 | 04:16 PM
440 sixpack's Avatar
440 sixpack
Always start with the ignition box and work from there. if that doesn't fix it then you start checking coil voltage, pickup coil and those things.
YoungDually
Mar 8, 2015 11:02 AM
Ndurbin10
Apr 1, 2014 07:17 PM
marcomjl
Mar 28, 2010 10:30 AM
nitronigs
May 9, 2007 08:47 PM
aj5601
1978 - 1996 Big Bronco
Oct 11, 2002 11:46 AM
