Gearing, RPM, MPH question
Old May 17, 2024 | 10:41 AM
rd65's Avatar
rd65
I am sure that with enough digging I could find this information but will ask here first.
1980 F350 DRW, 400, C6, 4.10 Dana 70, 235/85-16 31.6" overall diameter tires. I did not drive this truck much before I had to remove the engine for rear main seal, while the engine was out I bought new tires. I dont know what it was like with the stock sized tires, so nothing to compare it to.
My guess is that 60MPH will be giving the engine quite a bit of RPM. ???
Old May 17, 2024 | 03:22 PM
McLeod's Avatar
McLeod
Smaller tires will increase engine RPM but the tires you list don't seem that much different than what it would have had originally.
I would guess that engine speed increase would be negligible in what you have described.
Old May 17, 2024 | 04:15 PM
Conanski's Avatar
Conanski
Engine RPM Calculator | Spicer Parts
Check out the link to see roughly what rpm the engine will turn, I say roughly because the fact that the C6 doesn't have a locking converter means your actual rpms will be 100-200rpm higher.
Old May 18, 2024 | 05:26 AM
FuzzFace2's Avatar
FuzzFace2
As for the gear ratio there may be a tag under a cover bolt on the axle.
Also if you still have the cert. sticker on the left front door post, post up the info as we can then find what trans & gear ratio the truck came with from the factory.
As a WAG I would say 4.10 gears in a big truck like that meant to pull heavy loads.
Now note this was not all that bad back in the day of 55 MPH speed limits and non-over drive transmissions.
Today everyone is use to over drive transmissions and the low RPM the motors turn when they in a old car / truck with out over drive the motor is screaming going down the road.
BTW I have a 76 E350 van, 460 / C6and I am sure 4.10 gears, I used to pull a 2 car open deck trailer all over New England and also used it to pull a 1 car to Cali and back from CT in the early 80's.
Not once did I ever think the motor was screaming. Thirsty yes but not screaming
If you want to drop the RPM some Gear Vendor makes a bolt on over drive you could get.
Dave ----
Old May 20, 2024 | 10:59 AM
rd65's Avatar
rd65
Pics as requested
Old May 20, 2024 | 11:06 AM
rd65's Avatar
rd65
Looks somewhere between 2800-3000 RPM at 60. I never had the chance to drive the truck on the highway before rear main seal leak was a flow vs a drip.
mark a.
Offroad & 4x4
Nov 25, 2017 05:33 AM
Rusty Shackleford
26
Mar 30, 2010 02:30 AM
chipper
Feb 4, 2006 07:14 PM
CPerry
1997 - 2003 F150
17
Jun 23, 2004 10:54 PM
oregonian
1978 - 1996 Big Bronco
Jun 7, 2004 01:24 AM
