Sterling 10.25
Old May 16, 2024 | 08:51 PM
Pfdave's Avatar
Pfdave
1st Gear
Sterling 10.25
Hello, I have an 86 F250 4.9 4x4 with the Sterling 10.25. I took the rear end apart and the passenger rear axle bearing was bad and ate into the axle pretty good. I was wanting to get a new or preferably used axle to replace it. The current axle measures 29”. Everything I find online measure over 30”. Is there something I am missing? I can’t find any info on a 29” acle shaft. Thanks, Dave
Old May 17, 2024 | 06:13 AM
Franklin2's Avatar
Franklin2
If the bearing ate into the axle, you must have a semi-float rear axle correct? Just make sure you are not looking at the heavier duty full float Sterling axles.
Have you looked at a used complete axle? I do not know where you live, but you could go to www.car-part.com and see if there are any axles near you for sale at a junkyard. You may be able to get a complete used axle for close to the price of a new axle shaft. Make sure you know the gear ratio if you look for a complete axle.
Kollin
Oct 11, 2023 08:10 AM
BlueWhiteFord
Jun 9, 2020 01:49 AM
j_frank
Apr 27, 2006 03:03 PM
ddetrick78
Jul 14, 2005 02:17 PM
