Trans. Transfer Case ID?
Old Nov 26, 2003 | 03:59 PM
Wrecker's Avatar
Wrecker
I have a 1979 F250 4x4 with a 400Ci 4 Speed, and a Transfer case with a PTO. I need to replace the flywheel and clutch. I would like to identify the transmission and Transfer case. What should I look for?
Thanks
Wrecker
Old Nov 26, 2003 | 05:03 PM
wick246's Avatar
wick246
Does the transmission have an iron case and aluminum alloy top cover, or is it all iron? Is the transfer case iron? There may also be tags bolted to each component. Iron case with an aluminum alloy cover is an NP435 transmission. If the transmission is all iron it should be a T-18 or T-19 Borg Warner. There are two iron cased transfer cases the part time NP205 and the full time NP203. Let us know what you see...
Old Nov 29, 2003 | 10:39 PM
Wrecker's Avatar
Wrecker
OK.... here is what I saw ....Full Cast Tranny and Transfer case.
Tranny Borg Werner # 1301065804 with 6306 Just above the first numbers.
Numbers on the PTO on the Transfer case said: Dana Corp PTO #ANE71G
Thanks
Wrecker
Old Nov 30, 2003 | 11:47 AM
78fordman's Avatar
78fordman
Might be a dana 300 transfer case. Which is tougher, a t-18 or a NP-435?
Old Nov 30, 2003 | 12:31 PM
wick246's Avatar
wick246
Your transfer case should not be a Dana - only the P.T.O. unit. Here is a picture of an NP205 posted by RedJ. Notice the three bolt idler shaft cover in the middle. Thats the easiest way to distinguish between an NP205 and NP203.
https://www.ford-trucks.com/user_gal...oid=28475&.jpg
Old Nov 30, 2003 | 12:32 PM
wick246's Avatar
wick246
"Which is tougher between a T-18 and an NP435?"
I think they are both good and it is pretty much sixes. The T-19 is a heavy duty version of the T-18.
Old Nov 30, 2003 | 12:39 PM
wick246's Avatar
wick246
Funny I borrowed a picture from RedJ to show the NP205. I forgot there are pictures of my transfer case in my own gallery. Not very clear but have a look for some more details...
Old Nov 30, 2003 | 04:21 PM
Rockfrog's Avatar
Rockfrog
by the casting numbers you posted the trans is a T-18 .... you will only have one of two transfer cases in your truck (only the NP203 and NP205 were available in 1979) look for a two main housings bolted together for a NP203 and a short one piece main case for a NP205. These two cases are so dissimilar in appearance that one you've seen both there is no question as to which is which (the 203 looks like a 205 with another tranny bolted to the front and a big round housing bolted to the back).
even easier is to just look at the t-case shifter pattern ... if it goes 4L-N-4H-2H it's a 205, if it goes LOCK-LO-N-HI-LOCK it's a 203.
