"Intermittent" brake light
Old May 14, 2024 | 09:15 PM
Thoth88's Avatar
Thoth88
(if there is already a thread on this issue I'd greatly appreciate linking it here)
2004 Explorer Sport Trac 4X4
On my drive home I was informed that I "have no brake lights, turn signals are working". When I arrived home had my roommate jump in and test, my lights came on and then went out. repeated pressing of the pedal resulted in the lights not coming on. I have recently upgrade to L.E.D.s and thought that maybe one was junk, removed the lenses and turned on the running lights = worked, turned on 4-ways = worked, turned on running & 4-ways - all working. Scratching my head I set the driver side light where I could see it and pressed the brake pedal, at first contact brake light came on, as I added pressure the light went out, art full press the light came on but would got out with the slightest release.
Would this be a faulty brake pressure switch?
Relay hidden somewhere hard to reach?
Or what??
Thanks for any/all help/assistance.
Old May 14, 2024 | 09:50 PM
shorod's Avatar
shorod
If you have an incandescent test light, use it to determine if you have voltage to the brake light socket even when the bulb goes out. Or if you still have the original bulbs, swap out the LED bulb and see if the behavior returns to normal. If not, then start tracing the circuit back to the source, checking for voltage along the way. It sounds like at least the situation is repeatable so it should be pretty easy to track down.
-Rod
Randomusername
Oct 31, 2016 06:53 PM
V10Train
Electrical Systems/Wiring
Jul 31, 2012 07:48 PM
alliswc
1997 - 2003 F150
Mar 7, 2008 02:01 PM
Caplax40
1983 - 2012 Ranger & B-Series
Dec 16, 2007 12:07 PM
