Frame cleaning, prepping, painting, etc.
Old May 12, 2024 | 09:33 PM
portsample's Avatar
portsample
Bed crossmembers have gone from rusty to gone in about one year. No choice but to pull the bed, grind the old ones off, and have a set of Dorman 926-989 replacement crossmembers welded in. While the bed is off, I plan to pressure wash the frame, then Ospho basically everything, prime everything, paint everything, then apply undercoating where appropriate. Products are,
I may finish off with a treatment of FluidFilm. I live near the ocean, on a gravel road, in a place where they salt in the winter.
Question: What have others used on their rusty frames?
Thanks in advance.
Old May 12, 2024 | 10:14 PM
kd5zll's Avatar
kd5zll
Red oxide primer. Has handled a lot of applications for me. I have liked sher-kem enamal where ive used it, so far. And you can put a hardener in it as well, might be able to skip the undercoating altogether.
Old May 12, 2024 | 11:51 PM
JoshHefnerX's Avatar
JoshHefnerX
If you get good paint in, I'd prob skip the undercoating. That stuff can be just as bad as good - trapping water in - if it gets compromised instead of allowing it to drain out.
393foxrn
Feb 26, 2024 02:17 PM
Ford F-350 Man
Feb 13, 2021 07:22 PM
1994F2507.3L
19
Apr 11, 2014 04:28 PM
Undertheoaks
Mar 3, 2014 07:10 AM
unregistered guest
Aug 5, 2010 09:20 PM
