2005 E150 4.6 running fine with P0193 code
Old May 12, 2024 | 04:55 PM
dani9678's Avatar
dani9678
I’m troubleshooting a check engine light on a 2005 E150 with a 4.6L. It’s giving a P0193 code but the engine runs good. When running data stream, the fuel pressure sensor is reading 74.05 psi with a desired fuel pressure of 39.59 psi. Do you think the fuel pressure sensor is at fault?
Old May 12, 2024 | 05:56 PM
tabijan's Avatar
tabijan
Put a mechanical gauge on it to confirm actual pressure. You can rent a gauge from most auto parts stores. If it’s really that high, you’ll see it in fuel trim adjustments.
Sixto
07 E350 5.4 198K miles
Old May 13, 2024 | 05:21 AM
manicmechanic007's Avatar
manicmechanic007
Put a mechanical gauge on it where?
His has no test port if it has a one line system and a fuel pressure transducer
Sounds like the pressure transducer is faulty
You unplug that transducer to see the fuel pump dead head (put out full pressure)
Old May 13, 2024 | 08:56 AM
tabijan's Avatar
tabijan
No pressure test port? Annoying.
Scanner above shows 19.3% pump duty cycle. How does the pump driver logic decide this duty with faulty transducer? Defaults to some base map?
Sixto
Old May 13, 2024 | 09:30 AM
dani9678's Avatar
dani9678
Are you referring to the fuel pressure sensor when you say “pressure transducer”?
JWA
Modular V8 (4.6L, 5.4L)
Apr 18, 2022 03:41 AM
Amish Ford
Dec 7, 2018 11:07 PM
wbnethery3
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 7, 2013 03:33 AM
819jack
2004 - 2008 F150
Apr 2, 2010 07:06 AM
johncfox
Aerostar
Nov 30, 2004 10:56 PM
