1996 E-350 RV question
Old May 12, 2024 | 10:50 AM
Silverdeath200282's Avatar
Silverdeath200282
4th Gear
So, I have a 1996 E-350 motor home I’m trying to get running right. It has the 460 in it. It sat for years before I started working on it. It did not run until the fuel pump and filter were replaced.
It is only running on 4 cylinders (The passenger side bank). The drivers side bank appears to be contributing little to nothing and running rich. Spark plugs on the drivers side bank are dry, but black and sooty. The cat is also getting red hot.
Compression is good. Fuel pressure is good. Appear to be getting good pulse on the injectors. Getting good spark.
It’s got a new fuel pump, fuel filter, distributor, plugs, and wires. Any direction to go in would be very much appreciated.
Old May 12, 2024 | 06:05 PM
Silverdeath200282
4th Gear
Anyone seen anything like this? Tried again today and stumped.
Old May 12, 2024 | 08:19 PM
Conanski's Avatar
Conanski
Does fuel pressure hold after the engine is shut off or drop to zero? It should hold and maybe slowly bleed off over several hours not drop to zero within seconds.
Also look for raw fuel in the vacuum line attached to the FPR, if there is then the diaphram in the regulator has ruptured and that fuel is sucked into the intake via the vacuum tree.
Old May 13, 2024 | 05:33 AM
manicmechanic007's Avatar
manicmechanic007
Your processor may be shot
Check the codes, check the processor output to the injectors with a noid light
Verify the map sensor output PID or the pounds per hour from the MAF using a NGS
Your OBD1 will output PIDS but you need an expensive scan tool to read them
I would first check all the basics again, like the firing order and the timing
Use a light and have the spout plug out
Run through that firing order again
Old May 13, 2024 | 10:08 AM
Silverdeath200282
4th Gear
It holds and there is no fuel that I can find in the FPR vacuum line.
Old May 13, 2024 | 10:13 AM
Silverdeath200282
4th Gear
I don’t have a code reader but I did take a video of the check engine light flashing. Anyone wanna take a crack at helping me decipher the flashes? I don’t think I’m counting them right.
Mdeshetler1
Oct 11, 2019 11:26 AM
wizkee
2009 - 2014 F150
Sep 4, 2018 01:00 PM
southernchaos
23
Mar 9, 2011 10:19 PM
rotun
Large Truck
Feb 6, 2011 10:25 AM
01Screw4x4
1997 - 2003 F150
Jun 8, 2005 11:38 AM
