Is this the heater core leaking?
Old May 11, 2024 | 01:50 PM
huesostew's Avatar
huesostew
Pressure testing coolant in my engine after I tore it apart in order to replace all the gaskets and seals, as well as add head studs. I've solved every leak but at 10psi I'm leaking in what I suspect to be the heater core. It's an open tube below the heater box. Any idea what this is? Or is it a drain for a condensation and the pressure is pushing it out the drain?
Old May 11, 2024 | 05:25 PM
tjc transport's Avatar
tjc transport
i ain't rite
by the looks of the hose i am assuming the truck has air conditioning. that is the A/C drain, and since coolant is coming out of it yes, the heater core is most likely leaking.
Old May 11, 2024 | 06:08 PM
huesostew's Avatar
huesostew
Yes it has AC. Thanks for your input
Ford SD
Jun 15, 2016 04:13 PM
sanders92
1978 - 1996 Big Bronco
Jan 18, 2016 08:51 AM
Hardcase_Ford
Bronco II
Nov 11, 2008 10:07 AM
mrkevin
Aug 11, 2008 08:03 PM
slmd350
Sep 4, 2003 10:55 PM
