Stryker level kit
Old May 10, 2024 | 07:30 PM
Kameron Rice's Avatar
Kameron Rice
Stryker level kit
Anyone done the Stryker leveling kit?
thinking about adding that to my 2022 f350, anyone got any pics of a stone grey two tone matched ranch hand bumper on a red f2/350?
https://strykerordesign.com/products/2-5-f250-f350-leveling-kit?variant=40533038661655
Old May 10, 2024 | 07:52 PM
4wd6.7L's Avatar
4wd6.7L
I can't say I've seen anyone with that kit. Looking at that link it doesn't look like anything special, just a spacer lift with bling bling name plate. The rest is just the ordinary drop/relocation bracketry like you would find in a Ready Lift kit.
Old May 10, 2024 | 07:58 PM
Kameron Rice
that’s what I figured, I will most likely go with the ready lift kit as it’s cheaper, but I have seen several dealers install them, looks like a new brand
Old May 10, 2024 | 08:15 PM
4wd6.7L's Avatar
4wd6.7L
I don't know, in hand maybe there could be some noticeable quality difference, and if the name plate is appealing it might be worth a small up charge. But a Ready Lift 2.5" leveling kit is essentially the same thing.
Old May 11, 2024 | 06:06 AM
speakerfritz's Avatar
speakerfritz
I have the Stryker drop bracket
stryker bracket, made of welded plate steel, does not rub on pitman arm, has a square washer to set the lift height….so if you later change your height…you will just need a new washer.
ready lift bracket, made of cast, some times rubbed on my pitman arm, if you change your height you will need a new drop bracket.
also note…if you are at a lift height that requires a track bar drop bracket…you will need to do something to restore castor…other wise you will be ice skating all over the road. A lot of folks use bushings that go into the top ball joint of the hubs…couldn’t get my bushings out so I used a pinion arm ( aka radius arm) relocation kit. With a 3.5 front lift and a 4 arm relocation drop bracket I am at 3 degrees caster which is within range …so if I ever do this again I will go up to the next arm drop size so I can get closer to 5 degrees.
coil lift is my next move and pull the spacer.
also check if your shocks will survive a lift that is is at a height that needs a track bar relocation bracket….look at the shocks you have at rest…if there is more than 1/2 of the shock arm exposed…you will need longer shocks or a shock extender. If you have 1/3 to 1/2 shock arm exposed…you could probally get away with up to 3.5 front lift.
then there is the anti sway bar…sway bar drop bracket or longer anti sway arms…if your lift needs a track bar drop bracket you will need to do something about you sway bar.
for best ride, I would do a coil lift, new anti sway arms, radius / pinion arm drop brackets, shocks maybe.
that small aluminum bottom space will probally drive you nuts with the creaking sound they sometimes make. Use a top spacer if your going to do a spacer lift and use the rubber isolator top spacer have a avail so you won’t get creeking sounds.
Csaf350
Jul 16, 2022 09:26 AM
Edd505
All Things Towing
Feb 21, 2022 09:20 AM
jackjude24
Aug 19, 2017 07:30 PM
