Is it genuine ?
Old May 10, 2024 | 04:09 PM
Ericfromfrance's Avatar
Ericfromfrance
Is it genuine ?
Is This part genuine ? If no, may i toss it ?
Old May 10, 2024 | 05:00 PM
85e150's Avatar
85e150
That's aftermarket. Bought one similar to that for my Mazdarati 4 decades back....
Old May 10, 2024 | 05:36 PM
SlikWillie's Avatar
SlikWillie
Not OEM. Dentsides didn't come with coolant overflow. Also, your windshield washer tank is not OEM.
Old May 10, 2024 | 05:44 PM
Ericfromfrance
Is it only to ovoid to spread overflow cooling liquid on the road or is there an other purpose ?
Old May 10, 2024 | 06:10 PM
Beanscoot's Avatar
Beanscoot
It keeps the coolant from deteriorating as quickly as with an "open" system, since it keeps the radiator completely full. Also reduces corrosion in the entire system.
That is, if the system is working correctly.
Old May 10, 2024 | 06:27 PM
85e150's Avatar
85e150
IF working correctly, it will allow any overflow to be drawn back into the radiator.
Old May 10, 2024 | 09:03 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 not OEM at all, but if it is working like is should why remove it? Same for the window washer fluid reservoir, yea NOT OEM but it is works, roll with it.
Old May 11, 2024 | 06:57 AM
Ericfromfrance
I’m not sure it works well cause it’s alway empty, this is why i wanted to toss it
Old May 11, 2024 | 11:20 AM
Beanscoot's Avatar
Beanscoot
If you are in France, maybe the closed system was something put on vehicles for the French market.
Old May 11, 2024 | 01:20 PM
SlikWillie's Avatar
SlikWillie
Our systems won't suck back any coolant from an overflow tank. Unless you have a different radiator and cap. Years ago, I looked into this as I wanted the security of an OF tank. I learned that it just wasn't designed for it. Somebody correct me if I'm wrong and please provide proof.
Old May 11, 2024 | 04:32 PM
Beanscoot's Avatar
Beanscoot
I think you just need the correct cap, the radiator can be the same.
Old May 11, 2024 | 05:47 PM
Ford-F100's Avatar
Ford-F100
I added one on my F100 along with the different radiator cap needed for it and it works fine.
Bob
Old May 11, 2024 | 08:48 PM
85e150's Avatar
85e150
Bob
X2, mine came with a different cap.
Lowdog
Oct 1, 2024 07:59 PM
MannyC750
Dec 16, 2021 03:27 PM
kla94
Feb 8, 2016 08:08 PM
