2009 4.6 3 Valve engine.
Old May 10, 2024 | 03:11 PM
308223's Avatar
308223
4wd High
My wife's 2009 f150 has a 4.6l 3 valve engine in it. It dropped a valve into the cylinder as she pulled out the driveway, no warning, no loud ticking. I need an engine. Does anyone out there know of a reputable engine remanufacturer? I've seen Frazier engines all with mostly bad reviews. Powertrain products with some bad reviews. Jasper is another remanufacturer. Don't want Chinese parts. Other than a dealership, does anyone know of a builder that uses all Ford timing components in a rebuild? Or is this something I'm going to have to do myself? Any help would be appreciated!
Old May 10, 2024 | 03:35 PM
RLXXI's Avatar
RLXXI
If you have the tools and knowledge to DIY I'd suggest that route. That way you know what you've got. If it were my truck that I planned to keep a while longer, I'd go for the Ford reman or crate engine drop in. I'm Ford trained in engine repair but I'm also old and time is not on my side. So I'd pay to get the Ford warranty just for the peace of mind. I've dealt with Jasper engines for about 20 years and they do not impress me in the least with their skills of engine building.
Old May 10, 2024 | 07:41 PM
308223's Avatar
308223
4wd High
Thank you for your information I may have to go that route. Ford wants a small mint for an enĝ
Old May 14, 2024 | 05:01 PM
308223's Avatar
308223
4wd High
To: Mr. Electric 4.6l 3valve engine
I have the tools and know how. However, I lack the engine since this one's toast. Is the 4.6 2 valve short block and internals the same as the 3 valve short block and internals? Or are the piston crowns different?
Old May 18, 2024 | 05:25 PM
308223's Avatar
308223
4wd High
4.6 3 valve 2009 f150
I called the Ford dealer and a remanufactured long block is $5700 + 800 core. Not too much difference from other engine sellers. I know the truck isn't worth that much. But its in good shape otherwise. I'm leary about new used Ford trucks and the problems they have ie. Water pump inside the timing cover on v6 turbos or soft intake valves on 5.0 coyote engines. I loathe turbos, except on heavy equipment. 4.6 3 valve was good and had plenty of power. Buying and installing an engine is no car note and interest, and possible other problems with a used truck. Isn't anything made any good any more.
Old May 18, 2024 | 08:43 PM
RLXXI's Avatar
RLXXI
Welcome to the world of choices. Pick one that meets your needs.
Old May 19, 2024 | 01:43 PM
Johnny Paycheck's Avatar
Johnny Paycheck
FWIW, it’s the sideways 3.5 with the internal water pump.
That aside, why call Ford for a remanned engine price? They get them from the same rebuilders anyone else does. Avoid the dealer markup and call it a day.
Old May 19, 2024 | 05:23 PM
RLXXI's Avatar
RLXXI
Unless they changed in the last 20 years, Ford used only Fred Jones remanufacturing.
Old May 19, 2024 | 08:19 PM
308223's Avatar
308223
4wd High
Fred Jones manufacturing
To the previous post. If Ford uses Fred Jones manufacturing and it's the same as other engine builders. Who would you suggest that I purchase a reman engine from, that I wouldn't have fords markup? I have no knowledge of any reputable engine rebuilders.
Old May 19, 2024 | 09:10 PM
RLXXI's Avatar
RLXXI
It's not the same as other engine builders. Part of that added cost is the warranty you get with it. Like I said in my original post, I'd opt for that just for the peace of mind.
2009 - 2014 F150
May 9, 2024 07:55 PM
kvr901
Jul 23, 2020 05:58 PM
94powerstroke
2004 - 2008 F150
Jun 1, 2012 03:52 PM
jonshep
1997 - 2003 F150
Oct 6, 2010 03:24 PM
F150ATM
Modular V8 (4.6L, 5.4L)
Jan 16, 2006 10:31 PM
