F-450 Trim / Options feedback
Purchased a new Fifthwheel (Northpoint 382flrb) and she's a bit of a pig at 44' long and likely > 16k loaded.
The pin weight will be a bit higher than my current '21 3500 Ram CC LB SRW truck can (or should) handle.
Now that I'm going to a dually, the tighter turn radius of the F-450 feels like a no-brainer.
SO.... though I'll likely be ordering a '25, I'm looking at the '24 ordering options for reference:
Current Thoughts (Build sheet attached for reference):
F-450 Platinum in Carbonized Gray Metallic
Options:
- HO Diesel
- Snow plow prep
- FX4
- Hard folding tonneau
- tough bed (liner)
- front wheel well liner
- retraceable bed step
- Block heater
- All weather floor mats
- Max recline seats
- Console safe
After adding so many options, I took a look at the limited (build sheet attached)... adding the same options, the Limited is $110k
I don't see the $8k value in these differences? So far as I can tell, you get a better headliner (don't really care about that), the moonroof (I generally pass on those due to leak phobia) and 2KW power on-board (This would be nice, but I can add an inverter if I needed to).
What am I missing?
What options should I reconsider?
Is the Limited worth the $8k premium
I know this is all subjective, but folks here have experience
Console safe....yea, I get it. I use my console so a lock/locking device just gets in the way.
Hard folding tonneau...Okay you got a 5th wheel. So you want to lock up/protect stuff when not hooked to the trailer. I'd pass myself.
tough bed (liner)..I prefer Line-X myself.
retraceable bed step...I'd get the one for the side, but if you need help getting over the tailgate why not just drop the gate use the tailgate step??
Suggestions:
Ford Pro Upfit Integration System...Might be worth it for anything you need to add on to the truck in the future.
Rapid-Heat Supplemental Cab Heater...can help if you end up in an area with colder temps for a little help getting the interior warm.
Moonroof (Twin Panel)...I understand your concerns. For me I LOVE the huge opening for better light inside the cab. Pretty cool at night as well.
FYI : Once you are into the LR/Platinum/Limited trim levels it's all about forced options/packages and the interior trim/upholstery. So those $$$$ changes are driven by a few different things.
Good luck with your final decision. It's going to be a great truck!!
Camper certification- comes with a rear stabilizer bar.
FX-4 package - comes with skid plates and AT tires. Might be worthwhile, depending on where you intend on taking the truck.
Moon roof - I agree with you. I've had them on a few cars and never used them. Just a leak waiting to happen.
the supplemental cab heater comes with the snow plow prep package, so his build has that
if you don't care about the 2kw onboard, and can live without massaging seats (multicontour), reflective LED headlights instead of projector LED, and Halogen/LED taillights instead of LED/LED .... then that exact build in a Lariat Ultimate is $93,740
Last edited by wearenh; May 10, 2024 at 09:26 AM. Reason: couldnt get the link to insert, attached pdf instead
I see you have a block heater spec'ed. If you plan to operate in the cold I'd add the rapid cab heater too.
I would re-consider dropping the HO engine in a F-450. They are already geared down to a 4:30 ratio so the standard 6.7 engine has plenty of power to tow. I have the older generation in my 2017 with less power and torque and haven't wished it had more yet. Too early to tell if the HO is more or less durable than the standard configuration.
Consider adding the upfitter switches if you have any hint of plans to add any kind of accessory lighting or something in the bed that would need 12V power. Puts the switches in the cab and has fused/relayed wires under the hood for easy access.
Options:
- HO Diesel
- Snow plow prep
- FX4
- tough bed (liner)
- Block heater
- Max recline seats
- Console safe
What am I missing?
- HO Diesel (Save the $2,500, the standard 6.7 is more than enough)
- Snow plow prep
- FX4 (save the $495, not worth it)
- Hard folding tonneau (get it later, install yourself)
- tough bed (liner)
- Block heater
- Max recline seats
- Console safe (5 minute install yourself. I bought mine off eBay from a take off for $200 instead of $400)
I've owned 19 SD since 99, in every possible possible trim level with the exception of The limited.... I see no attraction to it.
I actually have no attraction to the f-450. I think the F-350 is a better option with the exception of the steering. I would spend the money to upgrade the trailer to electric over hydraulic disc brakes. You would amazed on how fast such a large mass can stop.
I've plowed snow for 22 years, some had prep, others not. I see no need for it on 450. I used to run a 11'2 blade on a F250.
